Is the air bleeder automatic or do I need to do it? Is it tin colored about the size of a shot glass with a Schrader valve on top? When you say close, is this the black rocker switch on the side of the taco valve?
Yes that is it and it is automatic. When the water flows any air bubbles are at the top of the pipe in theory and are collected and expelled out that. It has a cap but not a Schaefer valve to my memory. This is a wear item so every five years or so it rusts shut.
There is a Schaefer valve in the expansion tank. Don’t touch it.
Yes moving the arm on the zone valve opens and closes it. So if one fails you can open it till replaced.
Also if you have enough shut offs you can use those to segment and bleed system.
Water pressure is fine. If it gets to high the pressure valve will open and flood which is why I said keep an eye on it. Normally 30 psi I believe. So your auto fill will open if less then 12 psi and the pressure relief keeps it from blowing up.
The furnace should not come in if it’s up to temp. If it’s not getting called it just sits. If one zone is not doing that then it’s miswired and possibly not connected to the control box on furnace. Careful lots of volts in there.
