Stainless Steel Tool Box Work Surface
thr3squared
CA
I recently picked up a new tool box with a wood top, and would like to make a stainless cover to put over the wood.
To those who have this kind of setup already- do you what gauge metal was used?
:beer:
gloy
Any gauge you want if it's just a cover. If it will be a work surface it must be thick enough to not stretch at impact points, or it will expand and bubble up in spots and never be close to flat. If you want it thick enough for a work surface I would not go less than 13 gauge (0.093"). Typical stainless sheet is pretty soft because it is annealed for fabricating or folding without cracking, which makes a thin guage a poor choice for a workbench top.
T
thr3squared
CA
Thanks! And yes it will be a cover over the wood, but I will use it as a work surface. Its a pretty solid piece of wood, so no need to get rid of it.
tool_scrounge
Southern California
I have seen vidmar tool boxes with a 1.75" thick butcher block top with a 5 sided welded stainless steel box that fit tightly over the wood. The steel was about 0.09" or so thick. It looked to be a nice combination.
T
thr3squared
CA
That's what I was thinking of doing exactly. If I get the measurements right and its a snug fit I wouldn't even need to glue it down (though it probably wouldn't hurt).
