May have found my most useless socket...
Jason280
...a Stanley Workmaster 1/2" drive 12pt 1/4" socket. Not sure I can imagine any scenario where I'd need a 1/2" drive 1/4" socket, much less a 12pt one, but I have one just in case!
VocaTexas
Years ago a friend of mine tore down an engine that had 1/4 inch 12 point bolts on the main bearings. I can't remember what engine it was (4 banger, I think), but I do remember he broke a 1/4 drive ratchet trying to get them loose.
DSLTRK
PHELAN, CA
If it's broached deeply, you can cut an allen key to make an effective bit socket.
I made many bit sockets using cheap Craftsman sockets and good Elkind keys. peen the end to be inserted into the socket for a snug fit.
MikeF2316
Thornhill, ON
I had a '66 Volvo 122S (Amazon) back in the day. There was a 1/4" fastener that wrecked a lot of open end wrenches that was the adjuster for the rear brakes. Too bad it was square, not hex. A half drive square socket would have been perfect for that.
tym
It’s for snapping off rusted or seized bolts.
Come on guys.
Yep! Reminds me of when I snapped a water pump bolt on my Mustang with <20 ft-lb!! I think they were overtorqued at the factory and had yielded.
ChrisLS8
Not sure what engine would use main bearing bolts or caps that small. Even the 1.5 Hondas use a much larger size than 1/4 on the mains, my 2.0 Nissan had 12mm until I had em machined out for 1/2 Inch studs
ex-x-fire
Sheboygan Falls Wi.
I thought I found a weird one when I found a shallow 3/8 drive 7mm. I use it all the time for splash shields & trim on my cordless ratchet.
MoonRise
M6erfan
'Merica!
Shallow. Never seen 6 or 7 in 3/8 drive, all my set go from 8-24mm.
What set do you have? That's a great range for 3/8", I have no use for 6-7mm in 3/8".
My C'man USA set is 6-22mm and I'm pretty sure that I've never used 6-7mm sockets in that set. SK offer similar size sets as do many others. I'd much rather have a 3/8" set like yours that starts at 8mm and goes to 24mm.
M6erfan
'Merica!
You can modify your set easily to that range. Just take the unwanted sockets out, and dispose of them by trash, selling, or donating (or storing somewhere else)! Then, add a couple of individual sockets at the larger end.
Oh trust me, I've already done that. I recently added a 26mm shallow to my 3/8" set, I added 24mm years back. The smaller unused sockets are put in a "misc" bin in my box. Kind of like the junk drawer in the kitchen.
I'm more curious which manufacturer offers that size range. 8-24mm in 3/8" is about perfect to me and I've never seen that range offered in a chrome set.
Old Man Roger
Palm Coast Florida
It's for when you go to work on some piece of heavy equipment, and there's a sheet metal cover you didn't know you had to take off..lol
You were working on a dozer or a tractor, so you only brought the half inch drive tools with you.
M6erfan
'Merica!
Best answer yet ^^^
48RON54
Inland Empire, CA
I agree. I deal with diesel generators and air compressors and pretty much only use 1/2" drive. I ran into some bolts holding the fan shroud on one that were really small. Its been a year though so I can't remember if they were as small as 1/4". Its more likely they were metric though.
