Tracs
I have a Perfect Aire mini split that I use for heat on milder winter days. It makes heat down to 5F. It can get to -30F here in Manitoba in the winters and I have in floor heat for the main heat.
My problem is when the outdoor unit goes into defrost mode, the water freezes into the bottom of the pan. Last winter between the snow storm and the defrost cycle, the unit froze into a solid block and burned out the cooling fan motor.
I've been trying to think of ways I can ensure it doesn't freeze up again. The unit is on a patio stone at ground level. I did stick two 2x4s under the feet gaining 1.5" off the ground.
Would some sort of heating cable in and around the pan work? Any suggestions?
