thirdgoat
I have a 26x26 garage and a new 30x50 that is 6 feet away, running parallel to the other. There is a covered breezeway between (no walls) the two garages. The breezeway has a vinyl soffit. I decided to install my 5HP/60 Gallon compressor in the small garage, to keep the noise level outside the shop My question is can I just lay the 6/3 Romex type cable over the joists? It will be attached with wire staples on either side of breezeway where it enters each garage, it will be supported normally the remainder of the cable length., I just can't access the breezeway except the walls of each garage. The cable will not be subjected to any movement one installed. I just don't know if it needs to be secured over that 6' run through the breezeway. Thanks!
