Anyone else lube their ratchet with 5w20
HotelMike
CA
Changed oil and dropped the ratchet in the drain pan. I assume it will only do good :) I let it it soak a good 20 min while I got the filter out.
Steiger9
Nah I lube mine with hydraulic oil. Then drop them in the gravel...the dirt really holds the oil on the wrench and builds up a nice protective layer.
tym
I use exactly this in my non-sealed ratchets (fresh synthetic 5W20).
bonneyman
Desert SW
I had some Castrol synthetic 5w-30 that I used until it was gone. Seemed to work fine in ratchets that needed oil not grease.
seanb02
The Farm
This... I don't think I have any hand tools that haven't taken a bath in hydraulic oil. Some of them get bathed in motor oil from time to time, but hydraulic oil is the real deal around the farm. :spit:
Danglerb
SoCal
Oil should keep it from rusting, but does it have the film strength to offer any protection to the teeth in the ratchet when used?
Bretny
Dutchess county NY
Grease can clog up the ratchet mech. Use oil, any light oil will work. Atf, hydraulic, engine oil, its all the same for this purpose.
bonneyman
Desert SW
I was thinking synthetic oil "sticks" to metal parts, and that's one of the reasons why it offers superior lubrication. (Like in motors - The oil doesn't drip off the bearings and leaving them to start dry). Plus 5w is pretty thin, so shouldn't clog up some ratchets like grease would.
lardy1
Like asking in an online forum which motor oil you should use. Chicken/egg? Egg/chicken? Clean them occasionally and lube them lightly with SOMETHING. Unless you're obsessed with noise and attaining the absolute lowest level of backdrag.
Wamsutta
Amarillo, Texas
I use Permatex 81950 on non sealed ratchets. The old fashion MAC 30 tooth ratchets do especially well with it.
On sealed ratchets I use Superlube synthetic grease because it will not swell up the seals.
ganymede
New England
Might wanna check out the bearings in the motor if used oil from it is full of abrasive. :spit:
For totally non-sealed ratchets, I simply blast with PB blaster, then spin them around with my M12 drill.
Or you could change the filter when you change the oil.
davethorik
Norka, Ohio
Modern Wright ratchets have OIL ONLY stamped into them to help you remember. I've used Shell Rotella in them with success. And that is clean, new oil, not used.
joe_pinehill1
Northern Virginia
On a related note, used motor oil is a cheap alternative for chainsaw bar oil. Works great on my chainsaw-on-a-stick.
I used to use motor oil I drained from the cars for years. I switched to Canola oil. When I'm done with the saw I pour out the left over canola oil on the ground, and saves the mess from small leaks when I store in the garage and its cheap.
joe_pinehill1
Northern Virginia
I have never used any lube in any of my ratchets. One of the ratchets is nearly 70 years old and functions really well.
Same, I took apart one of my Father's SK 42470 ratchet circa 1939 a few weeks ago, more out of curiosity how the teeth looked. No sign of wear and it works fine. For years this was the only ratchet we had and was used on a farm and the house. I thought about not oiling, but it did have some kind of film of oil, either from spill or original I dont know. But I think over oiling can be a dirt magnet.
48RON54
Inland Empire, CA
Was this accidental or on purpose? Just curios.
I've dropped many a ratchet into the oil drain pan on accident. I usually wait awhile to pull it out since the oil is usually hot AF lol
isb cornbinder
I agree with the dirt magnet thing. If my ratchets were in continuous rotation, I would consider lubrication and a scheduled service. A ratchet does about a 1/4 turn then locks in the other direction. This is not high wear due to heavy loading. My Dad bought my oldest SK 1/2"ratchet in 1940.
I took a SnapOn garage sale torque wrench in for service and calibration. The ratchet would skip without warning. I got the torque wrench back in a week. The attached note said, no parts replaced. ratchet mechanism cleaned. Wrench certified, no charge.
ken w.
Western New York
SK rebuild kits come with a small bit of synthetic grease and an instruction sheet showing where to apply the grease. To me it looks like Superlube.
BK13
PDX, OR
Yeah, kinda what I do. When I get a new ratchet I usually try to get it douched up with Quantum Hot Sauce fishing reel lube. But older rats generally rely on the used motor oil or ATF bath.
KBigg
NE Indiana
Depends on the ratchet. when I restored my Wright 3/4dr 18 tooth ratchet I packed it with red grease and it sounds/functions smooth as can be. The rest of them I usually use whatever I have laying around, motor oil, ATF, 3in1, air tool oil, pretty much anything and never had an issue. Seems the lower tooth ratchets like heavier lube.
bpjr
Florida east coast
I used 30w motor oil and then Super Lube for yrs but a couple yrs ago started using the synthetic Penn fishing reel oil...cause I ran out of Super Lube and the Penn oil was handy. Use it on my guns too.
kctyphoon
Jersey/Staten Island
Anything is better than nothing imo. I think the more important thing is keeping the rust away, but the added smoothness from something like lithium grease is just a bonus.
Guy i work with just had an old Stanley Professional ratchet (thats what it says on the thing, i have no idea if theres any real difference) that i just fixed for him. It would jam and I’d actually have to bang the selector down on the truck to force it to switch directions. I like the selector switch on it. Its just one big rocker style that when working, you can easily swap directions with the same hand your holding the ratchet with. Let it soak in wd-40 with some bar and chain oil (cause thats all that was on the truck) for like 2 hours. Took it out and coated it with some white lithium grease. Works like new. Its so used the chrome is wearing off the selector. The same socket has been on that thing for years, maybe even a decade or longer.
