signcrafter
- Joined
- May 9, 2012
- Messages
- 12,665
I'm slowly redoing the wiring for the shop when I get time. The previous owner has a mess of romex wires strung all over and stuff added and added and added. So I'm starting fresh. I'm doing all mine in conduit since I have a bunch and it kind of future proofs things if I want to add a circuit down the road it will be easy. Breaker box is in the house and a block wall separates the house from the shop. So I cored a hole through the block wall and ran a piece of 2" pvc from the panel out to the shop and put in a 12"x12" pull box there. Then running 3/4" and 1/2" conduit from pull box to the various circuits in the shop. There won't be too much out there, 220 welder(already ran), 220 compressor(still need to run), 3 lighting circuits(ran in romex now but will be changing soon), an exhaust fan, then some outlets. I'm sure there will be other things but that is it for now.
My plan is to put all the switches by the man door leading into the shop from the house. There will be the 3 lighting circuit switches, a 220 switch for the air compressor, a switch for the exhaust fan, and a switch for a wall mounted cooling fan. Want to be able to turn everything off from this location since these items are located around the shop and depending on what's being worked on can be a pain to get to sometimes.
So my question is what if any neutrals do I need at these switches? The switches will be located away from these items( I will put a disconnect located at each item as needed to meet code). So the easiest way to do this would be to pull a hot wire for each circuit from the panel to the switches and then a switch leg from the switches to each item. This could be done by running conduit from my main shop pull box to a J box centrally located between my items. I would run a neutral for each circuit to this J box also. From this J box I would run conduit down to my switches. In this conduit I could run the hot from the breaker for each circuit down to the switch and then a switch leg back to this J box. So to make it work really only need a hot and switch leg to the switch boxes. But code requires you to have a neutral at every switch location right? So do I have to run a neutral for every single switched circuit I'm running? Seems like a waste to me since there will be around 6 switches and the neutrals will all be dead ended in the boxes.
Hopefully my description and question makes sense. I would draw a picture of the layout but not sure how to do that on my computer. Just seems like such a waste to me to have to have a neutral from every circuit pulled to the switch boxes just to be dead ended and capped off. Plus would mean I will need to run more then one run of conduit because of the amount of wires in the conduit then, I think, didn't count them all up yet.
