Just in case there was a misunderstanding, I wasn't implying the ratchet wouldn't be correct for the smaller set. I'm just trying to figure out what set Dan has and is building, because after the common ratchet and a couple of the basic handles and sockets, they do differ. My main reason was the midget wrenches, because the big set has a lot more and two different kinds of them. But there is something afoot here with Dan's set. I have an undated catalog (that I have suspected to be late 1940's) and it is basically the same as the 1952 you are using. (There is an NM-4 and -5 set, but they are inconsequential to this discussion.) His box appears to be the same size as the box the NM-6 set came in, but the contents he has sure do look more like an NM-8, including the square-shank composite spinner. But, Dan's box has a different logo than the wartime through 1947-ish logo, OR the late 40's to early 50's logo. Is it after that? Maybe they did cram the bigger set in a smaller box?
Dan, I'm curious to know which pieces were original to the box when you found it and which have you added?
