Spike00513
- Joined
- Jul 18, 2012
- Messages
- 47
Not sure if this is the right subforum.
Tried searching and am still reading threads.
What is the best 1/2 impact? Mainly for wheel removal, but it doesn't hurt to be capable of doing more.
I can always buy more different impacts for other purposes. Both air and electric, such as stubby ones for tight areas.
The Milwaukee 2767 (1/2" High Torque) seems popular. Affordable and strong.
But they don't advertise the decibel level, so it's probably loud.
I'm looking for a quiet one, because why would you ever want a loud one?
The biggest Ingersoll Rand 1/2 has an optional "Quiet" version; I hear it's just foam in the exhaust that can later cause problems and make people want to remove it. And even that one might not be that quiet.
I think some Aircats go down to 82dB but may be less reliable.
the IR "Quiet" one might still be loud around 90dB. Others are around 100dB.
I'm not sure if other factors matter. Like torque power; if that makes it undo a bolt easier and quicker.
Strikes per second, and so on.
Honestly, I don't think I've ever even tried removing a wheel with 3/8" before anyway. Just 1/2".
I'm not sure how much weight matters. Because air impacts seem lighter, 4lbs or less. While the Milwaukee electric High Torque is like 6lb.
Plus, if using an air hose, you can lower/drop the air tool down to the floor.
Electric, you can place aside on a lift post while removing a wheel, but it could fall over onto the floor.
Part of me wants to try the big titanium quiet Ingersoll Rand,
or electric
or simply making a chart of all the different tool options based on decibel level, and choosing the quietest one
I imagine a small weak tool would be much more dramatic about removing a bolt, vs. a powerful one making quick work of it
Snap-On also has a 1/2; I hear it's angled in a better shape than the Milwaukee. But it probably costs a kidney, and I hear they have worse warranty and start to break/go bad soon.
or electric
