bikesandcars
- Joined
- Nov 4, 2016
- Messages
- 127
using mini-split or heat pump for radiant slab?
I have a situation that I don't think is very uncommon, but a solution seems hard to find. I'd like to heat my radiant slab with a heat pump.
60x40 insulated garage (post frame) with radiant slab. Insulation is very good (2" spray foam walls, R38 ceiling, insulated doors).
Right now I'm running an electric on demand water heater to heat my slab. It works nice and is quiet but it does chew up the electric. It was cheap and a way to keep the slab from freezing.... turns out we use the garage so much I want to keep it warmer than planned.
next year it's in the budget to replace my window unit with a mini-split or other A/C - heat pump system, I'm thinking 36kbtu
Has anyone heard of or used a mini-split or traditional heat pump system that has a heat exchanger to heat water directly so I could use it for my radiant slab? My total calculated worst heat demand is 44Kbtu, I get by on much less than that based on how my current system cycles.
I don't want to cool the slab, that would lead to issues with condensing water on the floor which I don't want.
