This will sound weird because of the layout but it's part of my new shop build that will start soon. So my idea is to climate control two rooms with one single stage mini split.
So all block construction. Two room, each 8' X 15' butted together on the 8' end. Basically an 8' X 30' room with a block wall in the center separating it into two rooms.
One room will need to be as cool or warm as I want it to be for comfort. The other will just need to be climate controlled for storage purposes (not super humid, super cold, or super hot).
So, what if the block wall between the two room has two block left out. One near the ceiling and one near the floor, in the center of the wall. Each missing block had a fan installed blowing the opposite direction as the other. The purpose would be to exchange the air between the two rooms.
So, as the single stage mini split controlled the one room to the comfort level I wanted, and the air was constantly exchanged between the two rooms, it seems the other rooms would stay at a reasonable temp and humidity level for storage purposes.
Thoughts? Is this ridiculous?
