TravelingLight
I'm wrapping my 12x20 shed with tyvek this weekend. And I'm ready to put in the two windows (basic, single hung). I've watched different videos and read different stuff, so I want to make sure my plan is sound and complies with 2015 IRC.
My window rough ins are 24 x 36. The windows I am installing are 23.5 x 35.5.
First, I plan to wrap with tyvek, and cut out the wrap covering the rough in opening. On the bottom and sides of the window opening, I plan to fold the tyvek into the rough in opening and secure. The flap of wrap at the top of the frame will go over the window flange.
Question 1: If I am doing the tyvek this way, do I still need to also use window flashing tape?
Next, I'll put a bead of sealant (exterior, window grade stuff) around the flange so it seals between the flange and the OSB sheathing. Insert the window and check for square/level.
Question 2: Since my window is a half inch less than my rough in opening, I'll need to shim. Am I correct that I will first shim the bottom of the window to lessen the gap up top and essentially get it centered in the opening? Then shim the sides to get it centered there as well.
Then, I'll secure the window to the opening with fasteners through the flange. Then I will put the top flap of tyvek wrap over the top flange.
Questions 3: At this point I should put flashing tape around all four sides of the window, correct?
Finally, I'll install my 1x4 trim boards around the frame, caulk around that, and use spray foam on the inside of the shed to seal/fill in space around the window.
Question 4: Should I do a 1/8" gap around the window between the window and the trim pieces to allow for movement?
Anything else I'm missing or anything I should do differently? Thanks.
