PearlWhiteGT
Looking to get my first cordless M12 Ratchet soon for general DIY automotive stuff at home. Do you guys recommend the Fuel or Non Fuel version?
Handle them both...see what you like best for weight an size
In general "break away power" is a pretty moot point...
even a FUEL won't set your pants on fire there!
Weight is a factor. As is cost in general.
Fuel 3/8" is larger, heavier than its brushed counterpart but built much stronger
I have them both...I like them both
I'm a fuel guy usually and have a ton of fuel drills, impacts, and other stuff. I got my non fuel ratchet for free as part of a deal. I have no intention of getting the fuel version at this time. Also I want to get a 1/4" ratchet and will go with non fuel due to it being smaller and can get into more places.
Ratchet or ratchet impact.......two completely different tools. Most are ratchets not impacts.
Ratchet break fastener by hand and spin it out !!!!! Same on spin it in and torque by hand.
“utilizes a powerful 12-volt motor to produce up to 30 ft-lbs of torque and 250 RPM, giving users the power and speed of a pneumatic ratchet without the air hose”
The Fuel version runs faster and does have considerably more poop to it for tightening fasteners which is quite handy in some applications
Not really an issue. No one is going to run it long enough to need to replace the brushes.Fuel. They have no brushes to replace.
I have the non fuel one and like it. The fuel ratchet has more torque but when I'm using mine torque really isn't an issue. No matter which one you get you have to break the bolt free by hand first and then spin off with ratchet power. I use the tool and just push with my hand to break bolt loose and then pull trigger, just like you do with an air ratchet. I've never had a bolt that my non fuel ratchet couldn't spin out after breaking it loosen first. The non fuel is a good deal smaller also so will get in more places.
What do you mean by "runs faster"? The fuel versions run at lower RPMs.
M12 Fuel 1/4 Ratchet 2556-20 40 ft-lbs 250 RPM
M12 Fuel 3/8 Ratchet 2557-20 55 ft-lbs 200 RPM
M12 Fuel 1/2 Ratchet 2558-20 60 ft-lbs 175 RPM
M12 1/4 Ratchet 2456-20 30 ft-lbs 250 RPM
M12 3/8 Ratchet 2457-20 35 ft-lbs 250 RPM
1/4 get the fuel.
3/8 get the non fuel.
1/4 get the fuel.
The non fuel are 100$ CAD here in Canada right now.
My vote is the opposite lol
3/8 fuel and 1/4 non fuel
You get additional 20lbs torque this way versus both being almost the same power.
But the non fuel 3/8 is much more compact than the 3/8 fuel. 1/4's are the same dimensions. I'm not concerned about 'oomph' power on tool like this.
it is nice to have though when you're working on rusty things. A lot of times ill break something free by hand and about halfway through the fuel ratchet still doesn't even cut it. gotta break it free again with a hand ratchet or the fuel and it gets to be a pain.
Wrong tool for the job.........choose wisely:
Would you guys recommend the 3/8 over the 1/4 for my first one for general automotive stuff?
I finally saw in person what the Fuel version is like and that's probably more like it. But I'm less disappointed in my current ratchet but I wish it was more 1/4" drive. Not sure if I want to spend what it takes to convert it. I'll just use an adapter for now.
I'm suspicious of the 1/2" drive version of said Fuel ratchet, I don't know if it really has the torque to justify that offering. My 2457-20 (non fuel) doesn't have as much torque as I'd like to see from a 1/4" drive ratchet.
I wouldn't really choose the FUEL vs. regular or the 1/2" vs. 3/8" for torque. I chose the FUEL over the regular because it's a beefier design - it's more useful as a ratchet because it is built more robustly then the regular one. I'm not reefing on it, but will see if I can crack a nut manually with it if the power won't do it.
