Why is round material available in pipe and inch/mm sizing ?
theoldwizard1
SE MI
Steel (not "water pipe"), aluminum and stainless are all available is these two different sizing standards. Same alloys. WHY ?
(I know the difference in the sizing and what Schedule 10, 40 and 80 means so bother explaining it.)
MattT
Total guess here, but maybe it's because the rest of the world is metric?
Not for pipe they ain't. "Metric" pipe threads are British inch threads.
Regards the OPs question pipe is for applications requiring pipe. Material sized by I.D. & O.D. is tube and hollow barstock.
matt_i
SE Michigan
If you want to connect it to NPT systems then you need the ID and OD to match up...
Anything else can be engineered. With thicker or thinner walls....ERW =electric resistance welded or DOM = drawn over mandrel.
Bogie1632
Southeastern Wisconsin
I believe this is a ASTM International requirement. I know they have multiple standards on marking different materials, along with a whole host of other manufacturing requirements. Most of their standards are available as .PDF for a fee.
Perhaps someone else on GJ has better GTS skills that can verify.
V/R
Bogie
T
theoldwizard1
SE MI
Pipe sizing and inch sizing are both American ?
Why, in the US, is aluminum, steel and stainless round available in both pipe sizing (where the OD stays constant for a given Schedule and the ID decreases for "heavier" pipe) and inch sizing ?
Old Man Roger
Palm Coast Florida
I guess I don't understand the question or the answer..lol
dr_clyde
Holland, MI
True pipe is it’s own system separate from all other tubes. All pipe is tubing but not all tubing is pipe.
Piping systems rely on a standardized system of sizing stemming from threaded connections. That way they can increase wall size thickness and schedule without the need for new dies and fittings.
For standard schedule 40 pipe, the size is APPROXIMATELY the nominal ID. But in pipe the dimension that matters is the OD, due to the need for interchangeable fittings.
Tubing is simply measured by the OD, ID and/ or wall thickness. 2 are specified when ordering.
If we were to start from scratch today, we probably wouldn’t have pipe as we know it now. Everything would be true tubing due to ease of manufacturing and modern tech. But the pipe system we have is a holdover from back in ye olde days and the sizes have slowly morphed into what they are today. Kind of like how a 2 x 4 isn’t 2 anythings by 4 anythings.
