Wamsutta
Which ratchet is smoother regardless of tooth count?
have the JR40, which I think is a long version of the JR30. Nice enough ratchet, but backdrag much greater than any of my Kokens. Reasonably smooth.
so I snipped the pawl spring a few turns and that really helped with the backdrag, but still higher than ideal for me.
thoroughly lubed it with SuperLube and that helped also with sound and smoothness.
Thanks. I'm a newbie to quality ratchets. Where can I buy extra springs in case I goof up cutting them?
I felt the need because the backdrag was way too high, along the lines of many of the high tooth ratchets I've used. And much higher than any of the three kokens I use regularly. Surprising, because I expected a premium USA low tooth count ratchet known for low backdrag to be comparable to koken. It wasn't and still isn't, but better than it was before the spring trimming for sure
Sent from my SAMSUNG-SM-G930A using The Garage Journal mobile app
You're not going to need to cut the spring. There's something going on with Todd's ratchet that's very abnormal. Everybody else says their 30 tooth Cornwell ratchet is the smoothest ratchet with the least amount backdrag they've ever owned.
Thanks. What might be the underlying problem with Todd's ratchet?
Oh, what's the best lube, eg Super Lube, to lubricate the internal gears?
Thanks.
Newbie here learning a lot from this thread and, in particular, you post. Please bear with my novice-level questions.
Can you walk me through what tool(s) you used to cut the spring and how you determined how many windings to cut?
Also, can you quantify or explain in more detail the back-drag feel and comparisons both with the Koken and before and after spring cutting?
Thanks
