Colored caulk
Reit38
Iowa
So i have a few gaps in in my osb walls/ceiling in my pole building. Example. Along overhead door framing or where wall/ceiling meet.....not the seams. Is there a colored caulk that is close to /doesnt look bad with osb. I dont plan on painting the sheets so i was hoping to get as close as possible
Sent from my SM-G930R4 using Tapatalk
FANTM58
Brighton, Co
They sell a wide selection of colored caulk in the tile dept, to match the grout,
Sanded or not,,available at the big
Box stores
ard
Sierra Foothills... California
One of my issues with OSB and plywood as a finished surface.
IMO a skinny piece of trim, even a 3/4" x 1/2" strip would be better that caulk, primarily around the ceiling/wall. For the sheets in the middle, not sure there is anything that works well....
Falcon67
Merkel, TX
Box stores
Same, there are a couple that are close. I had some at the house that was slightly darker, Don't hardly notice unless you look right at it.
Slednut
Washington state
I did the ceiling of my patio with OSB, like said before I put a piece of OSB through the table saw then rounded them over with a router. I then primed it with oil base and painted it.
Prospecter
Maine
Generally, darker blends in better than lighter, IMO. Also, the OSB will darken with age.
