Teach me about derating please.
mm08822
Quote:
Originally Posted by Terry D View Post
No one meant sharing a neutral with two hots on the same leg. You definatly cant do that
That seems to be what the posted I responded to did say. Maybe the terminology is unclear. Most understood it as MWBC.
Quote:
It wouldn't even be called a neutral, it would be the grounded conductor.
NO, the EGC is a completely different thing. The neutral is typically connected to ground at the panel but is NOT a "grounded conductor". We have to make certain no current flows in the EGC or it may not protect life in the event of a fault.
A grounded conductor is not the same as an equipment grounding conductor.
A neutral is the intentionally grounded circuit conductor intended to carry current of the circuit.
neutral = grounded conductor
An EGC is also an intentionally grounded conductor. It however, does not carry circuit current and is present only to provide a low impedance fault path to ensure rapid fault clearing time.
Look up both definitions in NEC. read article 200 and 250 for contrast.
Quote:
A neutral carries the unbalanced load of a multiwire circuit.
Which by definition is a neutral shared between two hot wires and is not permitted, in general, by NEC.
Article 210.4 seems to read otherwise. They are permitted.
Quote:
Residential power is not 2 phase, it is single phase.
Engineers typically refer to it as two phase, which it technically is, but some electricians prefer the term split phase. The 240 VAC (or 208 VAC) voltage provided to the residence has a reference neutral and each leg of the 240 VAC is 180 degrees out of phase. Typically it is generated from one pair of a three phase supply, and whether it is 240 VAC or 208 VAC depends on whether the 3 phase is wye or delta.
Hayt and Kemmerly is the classic text and treats the subject well if you want to learn more about this.
Sure, any sinusoidal wave forms that have the same frequency and maintain a phase shift are different phases.
The original 2 phase systems had a 90 phase shift. It is still recent enough that confusion results based upon its prior configuration. Using the term split phase easily conveys the 180 phase shift obtained from one center tapped winding.
Generally, today when reference is made to 2 phases, it is used in the context of 2 out 3 the phase conductors found in a 3 phase system. A split phase secondary transformer is referred to as single phase xformer. You won't find a 2 phase xformer today.
Dh3256
I know Electrical Engineers and they don't call it 2 phase. I've NEVER seen a set of plans with the term 2 phase. (after 45+ years)
I disagree, so it's probably best to "agree to disagree" and you are entitled to your opinion.
alfredeneuman
Fullerton, CA
The EGC is NOT the neutral, per NEC.
Nobody here claimed it was.
Read again CAREFULLY
The EGC is a GROUNDING conductor
The NEUTRAL is the GROUNDED conductor.
See the difference? :lol_hitti
If a set of blueprints was submitted through plan check with 2phase, it would be rejected immediately
EDIT Are you just trolling?
alfredeneuman
Fullerton, CA
:withstupi
Yes, that is a correct statement, it seems you have that right now. Doesn't seem to be any value in debating opinions, so I will refrain from further comment or correction.
:bounce::bounce: I've always said and thought that. Read post #39. It's the first time it was brought up in this thread.
Facts are not opinions
Thank you for not posting any more :thumbup:
Happy Thankgiving!
mm08822
Who changed the channel???
Neutral = grounded conductor grounding conductor = EGC (post 38)
Dh3256
You may find it helpful to read more carefully.
I did not say I was not going to post any more, I said was not going to debate your opinions. Two very different things.
Some people want to learn, some don't, and I don't find it productive to help those who are not interested in learning.
I stand by the facts I posted.
Dh3256
I take your point, perhaps it would have been more clear to say "permitted only for specific defined applications" rather than "not permitted, in general"
Interesting, thanks for the history, have not really worked with the older technologies.
Pingel85
Green Bay, WI
But I still think you are not understanding AlfredN. Grounded vs grounding are 2 very different terminologies and something drilled into our head back in apprenticeship school. The “Ed” vs “ing” is where you are missing the difference. As other posters said a grounded conductor is the neutral (white or gray) and grounding is better known as equipment grounding conductor (green). Not anybodies opinion, just the NEC definition.
Dh3256
Grounded vs grounding are 2 very different terminologies and something drilled into our head back in apprenticeship school. ... As other posters said a grounded conductor is the neutral (white or gray) and grounding is better known as equipment grounding conductor (green). Not anybodies opinion, just the NEC definition.
No disagreement or confusion at all, I agree and that is consistent with what I posted.
mm08822
"(The neutral is typically connected to ground at the panel but is NOT a "grounded conductor".)" :spit: ...not in post38
MattT
Alfred is posting facts. You are the one posting asinine opinions. Please go troll somewhere else.
