I checked spec of my fluke 77 looks like it’s ok for dc amps
The amp clamp will allow your Fluke to measure up to 1000amps if needed, it uses a hall effect sensor to sense current flow and display it as voltage on your meter
You just do a simple conversion depending on scale
1mV per Amp/100mV per Amp
The DC clamp meter will give you a reading in Amps directly.
The point of this is that you can quickly check a batteries ability to absorb current without having to fully charge it
which makes it a lot more convenient
You just hook it around the negative cable and check the reading 5 minutes after starting (a good battery will start fairly high above 30amps and drop to around 5 amps when its fully charged)
Also good for alternators/Starters/fuel pumps/glow plugs in Diesels and anything else that draws current
Midtronics testers sometimes come with a current clamp and do this test automatically along with starter
Alternator and drain test (you can replicate the tests with a basic conductance tester and a current clamp with a little practice)
