joeswamp
This post is really directed at HiBall, but other jack experts please chime in.
OK so like everyone else on here I've learned a whole lot about floor jacks from all the recent discussions. However one thing I'm still confused about is floor jack seal design. It sounds like the "universal cheap import" jacks use O-ring seals (which fail quickly), whereas the good jacks use cup seals or something more substantial.
So for example, the AFF 200T:
is an example of a cheap import jack. We see on its part breakdown:
http://www.affjaxx.com/parts_docs/200T.pdf
That the ram is sealed by parts H3 and H4 (an o-ring and "o-ring returner"). I believe the o-ring returner is the part HiBall says not to mess up when you attempt to rebuild the jack, as they're hard to find.
Another Chinese jack, the $200 Norco 71232:
seems to use different seals on the ram. According to the part breakdown:
http://www.norcoind.com/norco/downloads/exploded/71232_Exploded.pdf
parts 80 and 81 (a u-cup seal and back-up ring) seal the ram. This would be a good seal design right? Norco's are Chinese but not made by Shinn-Fu I believe.
Finally, we look at a high quality floor jack, the Made in USA Milwaukee Model 40:
Here's the crazy part, if we look at the parts breakdown:
http://www.milwaukeehydraulic.com/model40.pdf
The ram is sealed by parts 68 and 69 (an o-ring(!) and 2 backup washers).
So what's the deal here? If o-rings are really that bad, why does Milwaukee use them? Or is it the Shinn-fu hydraulic unit design and/or quality that's the real issue here? What about Chinese jacks that use u-cup seals?
