threeputt
My home was built before the 3 wire was code. I am replacing an outlet on the outside under soffit so I can install my new outdoor security camera. The problem is both wires are white. I want to make sure I don't cross the two wire when connecting to outlet.
Is there a fool proof way to tell which wire is hot and which is the neutral when no ground wire was ever installed. It does have a metal outlet box. I touched one lead of my meter to metal box and I touched both wires one at a time. I got 40 volts on one and nothing on the other. Is this a sure way to tell even though I know the metal box is not tied to any ground ?
I also drove a metal rod in soft ground a few feet with a wire connected to it which would reach my wires that connect to outlet. One I got 50 volts, the other nothing. Again I assume the one I touched is the hot wire and other the neutral. If that is the case it was wired backwards all these years even though all I had connected was a motion light.
