Steel Roof Underlay
kylemac
Midland, Ontario
Hey Guys
Looking for some more opinions on my build, was just reviewing my roof drawings and my original plan was to just strap my 4/12 trusses with 1x4 and apply the steel roof, done this on a few barns sheds and porches but none of these spaces had an insulated space below them. The more and more ive been thinking about it and reading up on it, it seems like I should still be sheeting the roof and tar paper/ waterproofing, in my case I would probably do 7/16 OSB and tar paper and then strap 1x4 on top of this, due to condensation from the bottom side of the steel roof building up and then dripping or falling down onto your insulated space, obviously eventually causing mold etc. Am I right on this or do some people just strap and apply it? I feel for the extra cost of the OSB and tar paper it doesn't seem like much to save me a big headache in the long run
TractorJeff
Elkhorn, WI
Right or wrong, the 3 roofs I have done have the Tin laid right on the tar paper. One has an insulated room below it and the other two are cold storage.
PugetDude
Superstition Mountains, AZ
Condensation is the issue. several ways to deal with it. OSB/Tarpaper is probably the best option for a DIYer, another is to order the sheets with a FILC coating on the backside.
K
kylemac
Midland, Ontario
Thanks jeff,
what I was getting at was saying if you don't have any sheeting or tarpaper and just steel roofing on strapping it could cause an issue, in which you have sheeting and tar paper so I believe you did it the right way!
K
kylemac
Midland, Ontario
Now that im on the subject I guess now I really don't have to strap the roof since I will be applying OSB and waterproofing? I will be also doing vinyl siding over my wall sheathing and am now wondering if that is not necessary as well?
Bretny
Dutchess county NY
There was a thread on here a bit ago where the underlayment was spray foamed and ripping away from the trusses. So make sure you use a strong material built for this or OSB. Tar paper is not something I would bother with. If your in the snow belt use ice and water shield on the lower 6ft too.
dcg9381
Austin, TX
I don't think it was so much ripping away from the trusses, but it was falling off whatever moisture barrier or insulation that they sprayed the foam on to...
yeldogt
What's the manufacturer say/ recommend ....
There are just too many different types .. and the screw down "industrial" are particular/interesting because they need a barrier under them with living space .... because they leak
Ben W
NY
I used taped Zip sheathing and the metal directly overtop.
K
kylemac
Midland, Ontario
Thanks guys,
I think with all the talk I will do OSB sheeting and synthetic underlay for the roof, just too make sure I wont have any issues, and sounds like laying the roof right on the sheeting will be the way to go!
PugetDude
Thanks guys,
Use 5/8" (19/32) OSB- the screws can pull out of the thinner stuff in a strong windstorm- many jurisdictions here in the US are now requiring it.
Cost difference is minimal and you will appreciate the stiffer roof when you're up there sheathing it.
Bretny
Dutchess county NY
Yes OSB is pretty poor for holding power. At the cost of 5/8 OSB you should at least price out 1/2in plywood. I have found local lumber yards are cheaper than big box stores for this sort of thing.
