AlphaGarage
If you just want a clear look I'd recommend 5 mils of BondTite 1101 for the prime coat, 5 mils of BondTite for the top coat, and 4 mils EnduraShield for the clear coat. Depending on floor size that would be about $1 per ft2. For example, for 420 ft2, $420. But due to package size for 600 ft2 it would be $685.
If the floor will be seeing a lot of impact, tools & parts dropped, dragged, pounding from hammers etc., I'd probably suggest a bit more top coat just to help prevent chip outs.
Yes, we can go over most stains.
If you do little or no work in the garage, and just park the car there, we offer a very durable sealer which works on most stained concrete, AcryliSeal 3501. We believe AcryliSeal 3501 is the best water based acrylic sealer available. Wolverine Coatings was the first company in the world to commercialize this new type of Acrylic technology. To date we are still not aware of any other company that offers this type of novel technology. It’s slightly more expensive than the standard water based products, but it has a HUGE performance increase. AcryliSeal 3501 will give better darkening than the standard water based acrylic sealers but not quite as much darkening as solvent based sealers. But unlike solvent based products AcryliSeal 3501 is environmentally “green,” with no volatile organic compounds. The chemical resistance is awesome, not the same level resistance level of our epoxy based systems, but far superior than either other water based or solvent based acrylic currently available. It’s even resistant to chemicals including organic solvents like MEK, Xylene, Toluene, etc. This product is less than 3 years old and we have not heard of a failure to date. So, the durability is much better than either of the typical solvent based or water based acrylics.
AcryliSeal 3501 can also be used on bare, untinted concrete, it will darken the shade, and give the concrete a wet, glossy look.
AcryliSeal 3501 is sold in a 5 gallon kit, which will coat about 700 ft2 with two layers, which is what we recommend for most situations.
Alpha garage,
Two questions:
If I just clear the floor with your materials, how many mils of material am I looking at?
Can I put your clear over an actual concrete stain safely, or would you only recommend clearing over your materials. What I am looking for is an effect like this.
