Speedy, excellent video and shop. The urethane clear coat was a great idea. It will help protect your floor from chemical attack and the floor will remain glossy for a much longer time. That said, it will not prevent ambering.
It will act like a window, the UV will shine in and hit the epoxy and eventually will discolor it.
However when it occurs there are some options to truly stop this from happening, but for now enjoy it and keep us engaged in your channel.
In regards to the chip scuff a border around the chip, wipe it clean, dab in a small amount of 100% solids epoxy ( our version is SD Epoxy). You can use a green scotch-brite pad to scuff it.
If it’s small call it good, if large than you can clear it as well.
Thanks
