Vintage snap on friction slider fix
SpyderGiant
Inland Empire SoCal
So I got an old 1974 snap on box with friction slides. I know how to get the drawers out and everything, but one of the retaining catches on the slider attached to the box is straight up gone on one side. Any ideas how I could fix it? I’m no pro and no access and never have actually purchased from the box truck. Just want to know if there is anything I can do besides live with it. You can see the bottom one has the catch, but the top one doesn’t. be586513c2167dcbfa9e89418754a895.jpg
SpyderGiant
Inland Empire SoCal
Yeah if it’s in there I can’t get it. Not sure but I think this section of the slider is spot welded. Hoping someone is going to correct me.
SpyderGiant
Inland Empire SoCal
Can we get a closer pic of the damaged one.
Sent from my SM-A102U using Tapatalk
I know it looks raised from the angle, but it isn’t. I actually have a 2nd one that did this and it’s the bottom drawer. In a perfect world I would replace these with ball bearing ones, but sadly it’s an imperfect world.
harley jim
Cleveland Tn..........out in the sticks
If you were to put a pointed chisel in there and tap it with a hammer would it flair out enough to catch the slider. I know it may be a little off center but would that get you back together for temporary? Maybe.
FJ 432
Littleton Colorado
I used a pop rivet as a replacement.
Drill a hole in the exact location to match the rivet's diameter.
Use a pop rivet that will allow the clearance necessary for the slide. I believe I used a 1/8.
By adding this bump it acts like a catch. I hope this helps and it worked for me.
SpyderGiant
Inland Empire SoCal
Ooooooooh this is a much preferred idea because a river gun was included in my snap on donation. Thanks
SpyderGiant
Inland Empire SoCal
Man I cannot thank you enough. 15 minutes later and I was done. I added a little washer behind it as well and it worked like a charm. Gave me the chance to use some of the new (to me) tools. e6a5c9fb5e0812847cab429e9e85a026.jpg
Anyone have any recommendations on what I could soak the slides in to remove all of the grease that the previous owner thought was a good idea. I have the paraffin wax but need to get all of the old stuff out. Was going to just do one drawer at a time here and there and soak the sliders in a pvc pipe filled with whatever will get all of this **** off.
Lookin4'67Galaxieconv
Atlanta, GA
Put the slides on a cookie sheet, spray with Purple Power degreaser, let sit a few minutes then spray off with a garden hose. Then wipe down with a towel or paper towels to get the gunk off if there is still some remaining. Make sure slides have been wiped down good and are dry, lay back out on cookie sheet and add Evaporust to soak them in for about 16-24 hours. Once this is done, drain Evaporust back into a container (for re-use later) and spray excess off with hose again. Dry slides with cloth or paper towels and you're ready to lube and put slides back into box.
This is my procedure and works well.
tool_scrounge
Southern California
I soak slides in Kerosene and scrub with a tooth brush and a red Scotchbright pad if needed for light rust removal. I do this also to the slides mating surfaces on drawers and box. Note kerosene is flammable so I do it outside and obey safety notes on container. Then I carefully wipe dry with paper towels and q-tips before applying paraffin wax.
Please note when rubbIng on paraffin wax to Snapon drawer slides and mating surfaces, you can put too much on and have a little drag from the wax. With Waterloo (old Craftsman) and Kennedy slides, i have never seen issues with lots of wax.
tool_scrounge
Southern California
Another coment on applying paraffin wax.
I rub wax on all the mating surfaces. Then I install the top most drawer and vigorously slide the drawer in and out. Some of the wax will shed off to the bottom of the toolbox. Repeat with the next drawer down. Before putting in the last drawer, vacuum out the small bits of wax from the bottom of the toolbox.
SpyderGiant
Inland Empire SoCal
Thanks for the advice. When you put the wax on, do you melt it like a candle or just rub the bar over the slides?
SpyderGiant
Inland Empire SoCal
