When I installed the tubing before my garage slab was poured I failed to consider a temperature sensor in the system. The tubing is a two-zone system, where the two runs go into the slab from the midpoint of the 28' foot side, route back and forth out to each end on 12" spacing, and return to the manifold at the perimeter on the 28' foot of the slab. Aside from chipping out a section of concrete and installing a sensor covered with epoxy concrete, is there a sensor on the end of a long wire that could be fed into one or both return runs? A tee at the tubing where it exists the floor with a sealed fitting around the sensor wire would allow the sensor wire to route up to the boiler.
Now, of course doing it that way would sense the heating fluid more than actually measuring the slab temperature. It would take some time to correlate the fluid temperature to the desired floor temperature, but it would give me a way to monitor and control the floor heat with a thermostat once I determine what fluid temperature gives me the desired comfort.
This sensor is meant to be installed into a groove cut into the slab, actually sensing the concrete temperature:
Tekmar 072 - Slab Sensor (20' wire) - <FONT size=3><BR>The tekmar Slab Sensor 072 has a PVC plastic sleeve which is designed for use in soils or concrete. The 072 is supplied with 20ft (6m) of 2 conductor cable. <br><U>Specifications: </U><BR>Literature: D 079<BR>Packaged Weight: 0.37 lb. (170...
www.supplyhouse.com
If something could be added into the tubing itself then I wouldn't have to cut any groove into the new slab. Or, I just don't bother with an in floor sensor and adjust the boiler setting until I get the comfort level I want.
