Innovate1
What's the generally accepted method to accommodate doors, both people and OHDs in the foundation? I think the OHD opening is generally 3" wider than the nominal size of the door which allows the track and brackets to be attached to the 2 x that is on each side of the door. Only downside I see to this is that the 2x go to the floor and will wick up moisture. I suppose they could be held up off the floor an inch or two so only the trim goes to the slab.
On people doors I cut a 45 degree cut on the inside of the foundation on each side so the door could swing past 90 degrees as I don't have a wall to stop the door. Again I think the notch in the foundation would be 3" wider than the rough opening needed for the door with a bit extra for shimming perhaps.
Looking to be enlightened on this...
