The VISES of Garage Journal
zkling
Seems like forever since I have had time to fool with any vises or stands.
Just took delivery of this fine starrett 924-1/2 from Colorado.
Kevin dolled it up proper, new jaws and handle.
I'm really digging the profile of the handle ends.
This is the first starrett I have owned and are really looking forward to making a stand for it.
Royce
Nice, but get some handle bumpers on that pronto. The tapered ends on those and the craftsman are neat to look at but destroy the spindle eye in a hurry.
royce
fairbanks ak
Nice Starrett, Royce. Especially like the handle and jaw work. I’ve become fond of the Starrett and have now accumulated a few. What kind of stand are you thinking?
Thanks Vise,
I'm going to start with a salvaged light pole and attempt to make a column with this cross section.
I'll post when I get started.
Royce
doily_grunge
Australia
Very nice vice and table. If you do not mind me asking, what does a vice and table like that sell for in Australia? Thanks
I picked the combo up for $150 aud ($100 usd). The table is worth at least that. The vice you can still buy and new it cost around $800 so I’d say this one is worth at least $300
AngryBeaver
Lake Milton Ohio
dirt cheap... Used benches don't bring squat here, but some vises do. I know there are quite a few people here that have paid north of 500 for that vise.....
rusty65
Pekin,IL
This vise cane from Rochester NY which is where the Kodak camera factory was and this vise was owned by a engineer who worked in the factory for many years and graduated from a famous engineering school also located in New York. I believe it’s possible this vise May have been used in the factory to work on and or help assemble certain parts for the cameras.
dkroth
Rochester, New York
More likely used in an engineering department, product development area or the research labs.
Doesn't look like anything I've seen before.
I've scored two vises from ex-Kodakers. Both were Wiltons and they worked in maintenance.
XCMTB83
Iowa
Today I finally made some chips out of the 143B I last mentioned on page 3838. Yesterday I completed the fixture to hold the vise and today I was able to use it.
In one of the close-up pictures you can see the thin darker circle inside of the hole. This is the crack that I am closing up and hopefully keep from spreading. Just below this darker colored ring is the next diameter change where the threads for the 1/2-13 SHCS will start.
Everything went well I just need to get the swivel base retrofitted on it now. Progress!
XCMTB83
Iowa
Since I forgot to include the only picture I make mention of...
Old Radar
San Antonio, TX
XCMTB83--
Professional looking work! If we were closer, I'd ask you to take a look at my damaged Columbian 505. I requested repair advice from the herd back on post #76678 but got no response.
zkling
That one Rusty has looks hand built. Has all the clamps we use in my trade. Real nice job if hand made. Nice vise Rusty.
Exactly what I thought as well...indicator holder inspired. If so, I really appreicate that the builder took the time to machine the sphere on the screw eye instead of a standard cylinder, like those cheap wiltons.
XCMTB83--
Do you have a mill? I would consider cutting the jaw towers all the way back beyond the crack, put in a small shelf then drill and tap for bolt on jaws. That would fix your current issue as well as get improved jaw options.
KMScott
Nice fixture XCM, are you going to weld or braze too finish up the repair or depend on the 1/2" bolts.
XCMTB83--
Old Radar, looks like the upper part of the vise is broke and missing. No telling what was used to fill in the missing pieces. The T-style jaws pretty much take up most of the space. I have repaired many vises and do not have a answer for yours.
XCMTB83
Iowa
Thanks, KMS.
I haven't ruled out silver solder or braze I just need to do some more research and or practice on some scrap pieces. I haven't ever done any brazing or silver soldering on cast. I may have to ask you some questions about the topic later on.
Shiftless
East Bay SFO
jarhead:
I wonder if that’s a made in England model or one made after Irwin bought the name and moved production to a different continent. What does the other side look like? I believe the earlier and better made ones said “made in England”. Looks like original paint.
Either way, you got a big heavy vise that should do fine for anything you throw at it. Just fabricate some new jaws and have a great user.
You might find jaws with that exact bolt spacing somewhere or failing that, find some 6 inch jaws with holes suitable for use with your vise and drill and tap new mounting holes.
Smitty
USA
I just cleaned up the little Prentiss vise no 18 that I got last week. It has 2 5/8” jaws and weight in at 17 lbs. I was able to save quite a bit of the patina on this 100+ year old vise. I found something that I’ve never seen before on a vise and it has me wondering. If you look closely at the deck it has 4 slot head screw impressions in the cast iron.2d9d3e4e2a8766448d87f141ba9e3b96.jpgf500ec7910ced3a11a5dd9030b73afe8.jpg7e25cddcc46cf90494d409926f16a39f.jpg2dc985c713a71460e82f107d476c21f2.jpg69716aa168f92e6afa86148a6abf1b9a.jpg
Sent from my iPad using The Garage Journal mobile app
Smitty
USA
Thanks VA. Somebody really took care of this vise over the years, there isn’t a hammer mark on it.
I've seen screw heads and other indications of the assembly of the wood patterns before. Odd location for those - I wonder if those held on something that was used in the final machining operations, that was subsequently milled off? :dunno:
Smitty
USA
The first thing I did when I saw them was to remove the base and check the other side. They’re just imprints in the cast iron. My first thought was maybe the mold was on its last leg and they were trying to get a few more castings out of it.
jarhead
Colorado, near Morrison
jarhead:
Nice, a fairly modern vice, Record still supply jaw plates but they are not that cheap.
Thanks,
I do believe it is original paint, not sure on when made.
It has some codes on it...
I only paid $52 so I was happy.
AngryBeaver
Lake Milton Ohio
in the cast iron skillet world, screw head marks are very common, especially in late 50's wagners and griswolds (when wagner bought them out). Most people say they are molders marks to identify what shift, or what worker made that batch. this is the first vise Ive seen with them, though
Adderall
Illannoy
Finished this one up. One thing I noticed that the base, the static jaw body, and the center pinhole are not all concentric, thus when I spin the vise it sits off center. If I remove the center pin, the vise spins centered in the swivel base but seems more loose. Should I leave it in or is there. I harm in removing it? 20191227_231501.jpeg20191227_232047.jpeg
Sent from my SM-G950U using The Garage Journal mobile app
Z3K3Y
Canada
I personally believe the earlier Record vises have a full casting around the bolt down holes, I think Irwins first shot at making them cheaper was to put the 'slot' style bolt down holes. Im not positive on this. But ive had a few dozen different records myself and that was my observation. Still a hefty a vise! Ive seen 2,3,4,5,6VS and 3,4,5,6SQ (or maybe is was QS) the later models have a quick release with a half turn of the handle, they have the slotted bolt holes and were sold in the late 90's.
royce
fairbanks ak
I have a few things that really need done, but I could not walk by this vise any longer.
Got it stripped, parting lines dressed, high spots knocked down, flattened the tops of the letters and primed it with epoxy.
Also, radiused the back of the base to match the stand it will be mounted to.
There is one area with some porosity and a few pecker tracks that I'll mix some cabosil and epoxy to fill.
In the end, I'm thinking that some fancy paint is in order and I'll need to be a little fussier on the prep work, than usual.
Royce
Old Radar
San Antonio, TX
No mill and no mill skill. :( So the question is: Is it really worth it for me to pay a master machinist to have it repaired? I don't know what a Columbian 505 in good condition generally goes for, but I suspect it would be less than the repair. Then add in the cost of new jaw inserts.
Because I like to care for my stuff from the outset, I generally don't go for things other people have abused. Why I did here, I can only say I was predisposed to acquire a larger vise and got caught up in the deal--how bad could it be for $25? Well, now I know.
So, with neither the skills/equipment to make the repair myself nor any machinist friends to aid me, I believe the best course of action is to admit defeat.
Since the thing is too damn heavy to make bookends out of, maybe I can part out the handle and screw since they are still good.
XCMTB83
Iowa
XCMTB83--
Thank you.
I see the handy-work now that I look closer. That would require a mill and a machinist to repair which has already been stated. Is there anything wrong with it that is keeping it from being used?
XCMTB83
Iowa
So I came across an American Scale 66 today at an antique/2nd hand store. Out of curiosity what is the typical going rate for large vises like the 6" swiveling American Scale? As a general rule of thumb is there a certain dollar amount per pound?
trijeff
Northern Cali
I found a catalog from 2000 that shows Record vises were still produced in Sheffield at the time and some of the models have the open bolt/swivel lock variant. I think all Irwin production happened in China.
https://archive.org/details/AmericanToolCompaniesFullLineCatalog2000
Sent from my Moto G (5) Plus using Tapatalk
dannyr
Sheffield England
The end of Record in Sheffield was complex, at least including that they were bought by Bahco (the big Swedish tool maker) and then maybe a finance company before being sold to Irwin.
The big change was when they sold their patterns, tooling, large semi-automated Diesamatic casting line and machine shop to China/elsewhere and the Sheffield Parkway factory closed.
The part not sold to Irwin remained in the Sheffield region in name as Record Power, just selling some of their power tools etc but now outsourced (some from UK, much from the east).
Old Radar
San Antonio, TX
Thank you.
Beyond the fact that the front jaw brazing repair has failed and is being loosely held in place by two wobbly bolts through the holes where the jaw pins normally should go, it was still being used/abused by the folks at the industrial site where I picked it up. Since I have a couple of other vises and as much as I would like to employ a vise of this size, I don't feel the need to set it up for use in its current condition. But, technically, it is usable.
