Tools for home mechanic?
eyeball
Fokky - maybe I missed it somewhere in the thread but what are you planning on working on? Knowing that might allow for more targeted recommendations.
Otherwise, you may end up with boxes full of expensive tools that you will never need.
groundcoat
Manchester, NH
Milwaukee makes something called a demolition screwdriver. About $16 at HD. Finally, an ultra rugged screwdriver designed to be abused and beat upon with a hammer. Now my go-to flat blade screwdriver. An awesome tool worth owning.
bbrins
MD
It may have been mentioned already, but a set of chocks would go nicely with the jack and jack stands. Don't rely on the park brake or transmission to keep a vehicle from rolling.
MarvinBerry
Enchantment under the sea - NJ
rulers, files, mirrors, tread depth gauge, soldering gun, rivet gun, glue gun, heat gun, creeper, ladder, vac cleaner, wheel ramps, fire extinguisher
All good stuff, but yeah, extinguisher is never a bad thing to have around.
On that note goggles & eye wash kit can also be useful on occasion...
And if you need all 3 of those items at the same time your probably having a really **** day.
Citation
Indy
I suspect a lot of shade tree DIY are like me. We didn't start off with a big set of tools, we got by with a limited set and added to it over time.
On the OP's list I think they have a lot of the big stuff but things screwdrivers, pliers etc will be handy. Start a job and see what you are missing. Read through this list once you do a job or two then decide again.
Oh, one more thing, a web/YouTube video search for any job you are about to tackle. I think I'm very good at problem solving auto problems for someone who doesn't do this all the time. However, its much easier to search then watch someone else tell you what might be wrong. Especially if the problem is say a cracked solder joint on a turn signal relay. Easy fix once someone else tells me what's wrong. :D
BrandoJames
Tornado Alley
Oh ok. I've used a regular 🔨 for that...even once a tire iron worked in a jam
Not a good idea--I used a frame hammer last week to remove a corroded bolt from a battery. The claw end got tangled in some wiring on the back swing. That's when I realized I needed some ball peins. At the very least, buy one quality ball pein in your favorite size.
I posted a thread here last week, "Proto Ball Pein Hammer Set", where I got a lot of good advice. Note that Mac Tools rebrands the Proto hammers, and Matco rebrands the Trusty Cook hammers. You can save a lot of cash by going with the original manufacturer.
https://www.garagejournal.com/forum/showthread.php?t=439183
jgromada
Maryland (between DC & Balt)
I don't think anyone mentioned any electrical type tools. inevitably there are more electrical problems these days. Start with a good multimeter but there will be other types of crimpers, soldering irons etc as you go along.
thin_concrete
Tap and die set, ratcheting wrenches, good pliers and screwdrivers. I tend to buy used stuff, but high quality stuff that fits within my budget and have had some good luck. Some pieces may take some tracking down, so patience is key.
M635_Guy
NC
My hose-clamp flex driver has saved me a lot of cussing over the years...
m6z
Missouri
Has anyone mentioned a grease gun? I forgot a grease gun.
Sent from my Pixel 3a using Tapatalk
A lot of modern vehicles don't have grease zerks, so it really depends on what you are working on.
Buy your tools as needed. If you are just starting out, there's no reason to spend money on tools unless you need them.
Sent from my Pixel 4 XL using The Garage Journal mobile app
groundcoat
Manchester, NH
I suggest acquiring some tools that will get you out of a jam like thread chasers, ez-outs and a set of sockets designed to grip onto rounded bolt heads.
A set of good cobalt drill bits is a worthy investment for any shop.
crasher98
NW LA
Amen! and good left-handed drill bits too.
