That's a problem with newer windows. They are certainly more energy efficient, however the glass is much thinner than in older windows. I would say the most cost effective option would be heavy drapes or ear plugs until you get used to it.
Can't help with the OP's problem, but this above made me laugh because....I was born on 180 acres on a dirt road and our closest neighbor was 5 miles away. It was quiet. We moved when I was a kid to a new house on the side of a very busy 4 lane highway and nobody could sleep for weeks. After a few months we grew used to it and it was never a problem again.
Tall, full trees (Leyland cypress, etc) will absorb and suppress a lot of noise but you will probably get used to it by the time the trees get tall enough to make a difference.
I have a new construction home near an interstate and despite the double-pane glass, my bedroom is loud. Any solutions other than buying $500 window inserts or new $1000 windows?
Arbor vitae trees grow pretty fast.
It seems that way but as trees evergreens and heavily planted landscapes mature they do reduce the noise a good bit. I think because they mature so slowly you don't realize... until you clear a such a lot or landscape.Plants do almost nothing to absolutely nothing when it comes to noise reduction.
Sent from my SM-N950U using The Garage Journal mobile app
Could be but they also seem to like to put up concrete walls etc. at freeways for noise reduction, at least around here they do.
Or this for a home.
I know it's louder at my house with them than it was without and I know people who moved after the state installed them in their back yard because it got so bad.I disagree. I can clearly hear the highway 1 mile away from me in the winter when the leaves area off the trees. It's much quieter in the summer.
BTW, independent studies have shown the ridiculous $1mil/mile concrete "sound walls" we have in NJ actually amplify the noise.I know it's louder at my house with them than it was without and I know people who moved after the state installed them in their back yard because it got so bad.
They were really only installed because of cronyism. The CEO of the company that got the lions' share of the contracts was a good friend of the politicians on the EPA board who pushed for the wound walls.
Tommy
If they have em on both sides the noise might bounce back and forth and get amplified that way.![]()
There are two "easy" solutions to the double pane glass issue in my experience. I find random noise extremely irritating so have done a lot of work in my business and home with regard to noise control.
1. Replace with triple pane. They perform significantly better than doubles with respect to noise transmission.
2. Add acrylic/magnetic inner storms. I live on a busy street and have quite a few double pane sliders..each is about 2ftx4ft. The magnetic acrylic storms (they go on the inside) cut sound about 50% (a surprising difference). We have them installed about 2" away from the interior glass.
If you have an older home with no insulation, blown in cellulose is also quite effective at dropping noise transmission through an older wall.
I can vouch for these suggestions. I'm kinda obsessive about insulation, so FG batts, then added more cellulose, and later foam board inside. Then replacement triple pane. Each step produced noticeably quieter interior. If I was starting over, I would go with mineral wool batts and high density cellulose.
literally pour over the top of the walls
Tommy
