MrMark
I am considering either an aftercooler or a refrigerated dryer and I am trying to go thru all the questions of which would work best for me.
I can't run cooper line all over the place to create a cooling system because it doesn't make sense for me. I only want one drop. I want a filter/regulator on the wall and a quick connect to plug in an air hose. That's it. But I need to get the water to condense out of the air before it hits that filter and a length of rubber hose isn't going to get that done. I imagine a coil of cooper would get it done but it would have low spots in it that would not drain.
Even if you could rig a coil of cooper without low spots, like in a spiral vertical spring configuration, you are still going to need cooling fins and a fan to make the most of it. Of course, you could mount it in an ice chest and fill it with ice and have the baddest *** water separator of all time. Maybe for the home mechanic to paint a car this would be the best ever. But for occasional air tool use, impractical.
There is a device called the Astrocooler that would be ideal for my application, but it is ridiculously overpriced.
This leads me to the refrigerated dryer which can be obtained more cheaply, but need to be run for a while before use and consume too much electricity to leave running when not in use, which will be 99 percent of the time. The other problem I see with the refrigerated dryer is that the inlet air temp is usually limited to around 120 degrees. I would be feeding the dryer almost straight out of my compressor tank and I am concerned about the temp. It seems to me that the temp of the air out of the tank would be quite high on a high demand application and that is where you really need the cooling and water separation post tank.
If low demand, I am thinking that most of the water will condense out at the tank and not be a problem for most applications. After all the tank is a giant expansion vessel and the air will rapidly expand and cool as it hits the tank. I would be interested in any information on the temperature drop of the air at the tank.
I would also be interested in anyone who has an IR temp gun and a metal piped system to take a temp reading on the air coming out of the compressor tank and then again at a remote metal piped air drop. I would like to see how much the metal pipe system you have drops the temp as this is its measure of efficiency. Might as well take the temp out of the pump head as well for a total picture of what is going on.
So what is the best way to deal with this situation, where I just want a short whip hose to some sort of device, to cool the air and then to the filter/regulator? I mean the people that run the cooper all over their garage are essentially creating a poor man's aftercooler is all, so my thinking is that for those that do not need the drops located all over the place, let's use a real aftercooler or dryer and not the cluge cooper piped aftercooler.
Does this make sense?
Comments?
Comments?
. The team owner got fed up with it and called a plumber in to rip all the iron out and install copper. I went with copper because I did not want to thread pipe, to me, the copper is much easier to install. I'm sure others would rather do iron, so what ever works for you.
