Tool for deburring large conduit?
Innovate1
I have a tool like this for smaller stuff.
https://www.menards.com/main/plumbing/plumbing-tools/deburring-tools-parts/rothenberger-universal-internal-external-deburring-reamer-tool/11006/p-1444452512497-c-8607.htm
But have some larger stuff to work with that is too big for above. A box knife around the inside will work but not well. Is the tool linked below what most people use on larger pipe/conduit? I am using PVC conduit.
https://www.menards.com/main/plumbing/rough-plumbing/pipe-tubing-hoses-fittings-accessories/plumbing-tools/deburring-tools-parts/superior-tool-reg-deburring-tool/18850/p-1444444236231-c-8607.htm
tyme2par4
NH
I use one of those for deburring a range of things. Should work good for large conduit.
Terry D
St. Louis, MO.
I don't know what your cutting it with, but you shouldn't have many burs on PVC. Usually just running your finger around it is all you need
mobiledynamics
Gotham City
DWV for me is primarily no-hub. I will use pvc for vent tie ins.
Deburring tool on the inside easy. I've always looked at the specialty tools that supposedly put a -proper exterior chamfer- on the outside for proper glue-ps
I
Innovate1
Just use a deburring tool. I use the steel handled ones from Grainger.
Sent from my LM-V405 using Tapatalk
Yes, I am looking for some sort of tool for deburring. I have no idea what type of tool you are thinking of from Grainger...
I have a knife blade type cutter for up to 2". But it leaves a sharp edge - not really a burr but most tools I have seen are called deburring tools - just want to chamfer the edge a bit so there is no edge to catch on insulation. The effect may be minor but I have a long run.
Have used the swinging blade tool to deburr aluminum holes at work some years ago. Worked well so will pick one up and see how it works. I will have other uses for it too.
mobiledynamics
Gotham City
Going to have be some uber extra super gritty coarse sandpaper to make deburr either the inside or outside on schedule 40 or 15....
Terry D
St. Louis, MO.
Just saying, if you are cutting PVC and creating a burr sharp enough to cut you, you are doing something wrong. You are either making a jagged edge on it or possibly using a dull blade and burning it which might make a sharp edge. I use a pvc cutter up to 1 1/4 , bigger than that, a hack saw or saw all with a fine blade
Sent from my SM-G960U using The Garage Journal mobile app
johnnyradiant
Vancouver, BC
I have Ridgid like PBCambell links to. They work good. I also use the pen style in op post and Ridgid version of op's Rothenberger, along some others that have collected over the years.
alfredeneuman
Fullerton, CA
:lol_hitti
I cut my index finger on a piece of 1"PVC, cut with a PVC cutter.
Jim greengo
Behind my house
For pvc I just run my finger around it slow.
For emt I just shove my wire strippers in there.
For rigid a rat tail file or dremel works good.
For copper I use a reamer.
MJO
Deburring tool for the inside, Channellocks for the outside.
u2slow
BC
A coarse, half-round file is my tool of choice. Lives in my toolbag.
stokefire7
I use several things. grinder, Nicholson pipeliner, Ridgid cone reamer. Always carrying the Reed DEBO, I can do outside with it.
Norcal
We used a cone reamer in a Brace (as in Brace & Bit)
With PVC you would not need the brace but the backside of a Sawzall blade works too and no need to reinvent the wheel either, l carry a Imperial Eastman reamer that I can use on up to 1 1/2” pipe but works best for 1” & smaller pipe.
