Here is a newly acquired set by Browning Tool Co. of Bozeman, Montana.
There seems to be little about the company other than a tool few patents online.
https://patents.google.com/patent/US2552147A/en
https://patents.google.com/patent/US2586296A/en
https://patents.google.com/patent/US3061061A/en
Google books:
https://books.google.com/books?id=zmwVFdCsHzsC&pg=PA572&lpg=PA572&dq=roe+v+browning&source=bl&ots=qQGMg7maS-&sig=ACfU3U3FwTH_kbYW0rHZB657Osh7uLPmBg&hl=en&ppis=_e&sa=X&ved=2ahUKEwiugeWJmdnmAhUox1kKHU_hBxIQ6AEwBHoECAsQAQ#v=onepage&q=roe%20v%20browning&f=false
It would appear the inventors were Roe V. Browning (tool joint patent), Roe V. Browning with Cecil F Badgely (ratchet mechanism).
I wonder if the third ratchet mechanism patent above by Brow ing applies to a separate tool, a 3/8 drive ratcheting spinner under the brand Browning Tool Inc.. I’ve seen two different drivers by them over the years, a solid red plastic handle and a translucent ruby red handle.
As for the ratchet tools, I had a 3/8” of theirs for some years now and knew little about it. This kit came with two 3/8” and a 1/2”, one cross bar in each size, and several unidentifiable pieces. I hope you guys can help with those.
There are three double sided aluminum items with what looks like a large ball bearing in the end. Only the largest one is stamped. Also not sure what the polished and pointed item is, which tapers to the same diameter as the 3/8” drive cross bar. The funny thing is all of these parts look familiar but I can’t place them.
I have no idea if they even go with the ratchets.
There is also an empty slot built in next to the trio of unknowns.
Google books:
