Everett_45
Hey guys, at work a while back I was hand drilling 5/8" holes in some 3/16" angle iron. If I remember, I started with a 3/16" pilot and went up to 5/8". At the end of each hole the bit would grab and throw the drill around. I was trying to feed as hard as I could given that I was pushing horizontally while standing, and going relatively slow on the RPM. I had ground the drill bit prior, of course without a gauge or anything. It looked like 118 degrees. I tried slowing the feed and giving it more throttle and even then it grabbed. Eventually it broke through. I've experienced this before, drilling some 1/2" plate with a 27/64" drill. Factory 118 grind on that one.
I've read that you should go real slow on the RPM, I could've been going a little fast there. But my main concern is the grind. Is it true that a 118 degree will grab more aggressively over a 135 degree? Or is the grabbing attributed to my speeds and feeds? Interested to hear what you guys think.
