Kubota Tee
Just great. Thanks for sharing.
Rixtrix1 - thanks for your comment and following along!
What was the code for having a drain in the garage that close to the water?
try what you have already to see if you can use that gear again.
this site will also let you go to exact locations and heights above the ground for a better idea: https://link.ui.com/#
jeepxj - Thanks for your suggestion. Let me give a bit more explanation. Our recreational area is an 11 acre spread directly to the east of us across the lake. It is split into 2 "parks" which are shared by our neighbors. I help in maintaining these by mowing, clearing downed trees and branches, etc. There is no power anywhere in these parks, so I'm not sure how I could create a wireless bridge over to that area.
I am hoping to use a long distance access point designed for outdoor mounting - I believe there is a secondary POE ethernet port that I am hoping to use from the NanoBeam to make the connection. Something like this . .
View media item 99811
Or . . . are you suggesting that the NanoBeam can also be used as an Access Point for long distance wifi? Sorry if my questions don't make sense - I'm quite a novice at all this networking stuff.
This is an amazing build, I’m very happy I’m following along. You’ve done a hell of a job!!
), we were told that a 3" (min) sleeve would need to be installed along the east side of the barn. This was due to the slope and proximity to the lake. Apparently, the electric company does not trust their trenching crews unless it's a clear shot and flat ground.
RADIANT PEX INSTALL - PART 2
Several years ago, I loaned my specialized PEX air stapler to a friend in Buffalo, NY who has been renovating a 100 year old home for his family. Since I will need the air stapler for this PEX install, I was looking to get the stapler back to Michigan. To my surprise and DELIGHT, he agreed to hand deliver the stapler and stay for the weekend to help me get this job done!
Great surprise to have help for the weekend!! THANK YOU CHRIS!
View media item 99844
Cdecker, I think lots of us would like to see a build thread for the garage / workshop in your avatar.Your inspiring me to start a build thread of my own, and my garage / workshop was completed 10 years ago!![]()
It was a pleasure to have a small hand in this amazing build. Great job with the thread! Although I had the benefit of getting real-time updates as The Willows was being built, I am thoroughly enjoying following along as you demonstrate it in detail for everyone else!
Hey there sorta old neighbor! I used to live in Hudsonville, but that was more than a dozen years ago. Place is looking real good! I like.
I look forward to reading more updates!
one lucky fella. beautiful space, great building...i have been thru hudsonville before. Looked at property near grandrapids for a job, but job offer fell thru so stayied in Illinois. Shoulda moved when i had a chance, job or not. ohwell, stuck here until the MIL dies.
Whats the lake effect snow like there?
Just stumbled across this (now subscribed!) and am enjoying seeing you document your build in retrospect. I had good intentions to document my build when we expanded my shop 2 years ago, and did for awhile. Then, got behind and just gave up!! You have inspired me to get my build pics organized and resume my good intentions!
Great build!
Very nice! , except that thumb you did a number on poor thing.
Awesome build!
I hope you don’t regret how they ran your condensate drains for your minisplits. I always ran 1 1/2” drains when I had to go very far. Those small hoses tend to plug up with dirt that washes down the drains. With them all tied together you can’t blow them out very easy without plugging all the others.
All that room under the stairs, did you utilize it for a compressor room or plan on it?
