Tools of Japan
BMack37
I might have to give the gel version a try. I just got the tang through versions in but I like the heft and feel.
They're definitely not hefty but that doesn't mean they aren't high quality. They're about the same weight as the green Megadoras and compressed wood Vessels, maybe a little bit heavier.
Duker
Livingston, TX
Ordered from JDV Products (US distributor)? It's interesting that they'd bundle the 900 stubbies with the 930 series.
I got these through a seller on eBay as I had some bucks to use up. I have a small OCD when it comes to screwdrivers! They will get a small workout this coming weekend as I have to install a bunch of electrical plugs and switches in my shop this weekend.
HazetMatt
Underground
I posted a while ago about the Koken bolt extractors.. well I ended up buying a set from Frank's and they came in the mail today. They come in long and short and I decided to go with the long ones even though they were more expensive because I could foresee situations where the bolt breaks off farther down the hole. As expected for Koken they were flawless out of the package.
Put them to the test on a shock bolt that I've been trying to get out of my car for a year. The bolt was already completely hollowed out and chowdered from previous attempts. With the Koken extractor I managed to get a piece of the bolt which is more progress than I have made before, although I'll still have to tap it. I'm sure it's not advised but I put the extractor on my impact wrench at max torque and it held up just fine.
scubadoober
I am generally not a Irwin fan, but needed a small flexible saw for a vanity project. I was shocked when at Lowes saw that both of the Irwin pull saws were made in Japan. Possibly all of their pull saws. I just need to figure out who the OEM is for replacement blades. They call it a dovetail/detail saw. I need it for notching drawer boxes for Blum undermount slides.
measuredtwice
USA
Looks like Shark.
https://www.amazon.com/dp/B00004TBPU/?tag=atomicindus08-20
scubadoober
^^^Man you are quick! Thank you! The Irwins look much cheaper than the equivalent Shark. I will look for replacement blades and if I find them may get a couple more of the Irwin pull saws.
measuredtwice
USA
Haha! I recognized it. Amazon still has my order saved. I bought the Shark saw in 2006 for $12.95 shipped. I took a look at mine and it is marked with the replacement blade number "01-2204". I don't know if it will work with the Irwin saw but seems likely.
scubadoober
After a closer look the blade is not replaceable. I noticed the handle was a little different, and rubberized. Oh well, we will see how it cuts. I am sure it would be hard to buy a replacement blade for what I paid for the saw.
MetricTech
Cynthiana, Ky
I bought the shorter version from frank a year or so ago and Ive enjoyed them as well. I also have some larger koken external extractor sockets that work well 17mm to 25.4mm. They are made like turbo sockets
MetricTech
Cynthiana, Ky
I was looking at the Irwin and Vaughan pull saws on zoro when i saw they were all manufactured in Japan so i went on amazon and purchased this beauty.
measuredtwice
USA
67d1d4d90ac4fe04b4.jpg[/IMG]
Cool!
I think you're probably right. Probably not much difference in price.
mr.lemons
UK
Update on using these. I took the plastic OLFA A-1 to work and it lasted only a couple of weeks. The black end is removable and then used as a tool to snap off portions of the blade when they become blunt. Third time I removed the end the yellow plastic snapped. Too brittle. Currently using the metal SVR-2 in its place which I hope lasts longer.
Been using the SVR-2 at work for a couple of months now. Very Happy with this knife. Not only is the knife body proving to be durable but the stainless blades seem to hold an edge considerably longer than the non stainless blades. Thought stainless would be less durable vs carbon. :confused:
tylerg1
First amazon.jp order
Very nice.
Sent from my iPad using Tapatalk Pro
jimmyin3D
southbay, CA
Very nice.
Nice buy! Those are the best socket extensions out there in my opinion. Superior knurling on the ends, the wobble fix and also the price. You can’t go wrong.
mr.lemons
UK
Anex No.407 Mini. Screwdriver bit magnets.
Snug fit on PH2 bits but the hole is too big for PH1 bits so they rotate off centre. They do stay in place on PH1 bits so are usable.
Performed a very scientific experiment to compare a freshly magnetized bit to the same bit with the magnet attached. Magnetized bit could not hold larger than a 10mm 1/2" socket. Bit with magnet attached could hold a 19mm 1/2" socket.
Not sure if the extra magnet will help pull out stubborn fasteners or just get in the way. Going to take them to work and find out. :thumbup:
Edit. Relying on Google translate I could not find a COO on the packaging.
nichocha33
For those ordering from amazon jp, where did you find the Vessel woody screwdriver set, it keeps showing the shipping is unavailable to me on everyone I’ve clicked on. It’s possible that I’m doing something wrong as this will be my first order from there
jimmyin3D
southbay, CA
No sometimes things just aren’t available, I’ve waited a few days sometimes weeks for it to become available again. It’s kind of random.
If you want them more quickly I’ve ordered through eBay shipped from Japan, a little bit more expensive and sometimes the shipping takes a while. (There’s the 6pc set for about $60 right now estimated shipping time 2 weeks)
I’ve never ordered through global Rakuten but it’s like a Japanese version of amazon, and heard it’s pretty good. More competitive prices but I think shipping price will gouge you.
Good luck, and vessel makes great screwdrivers you’ll be happy with them I’m sure. If not in a rush I would personally wait for amazon.JP
Check out my for sale listing in the classifieds:
https://www.garagejournal.com/forum/showthread.php?t=438994
superautobacs
Vancouver, BC
I just looked at photos of the product card and it didn't indicate any COO. To me, that's implying that it's imported. My Vessel one stated "Made in China" on the product card.
I do have the MagCatch mini (part No.408) which is for shaft diameters between 4.5 - 5.5mm
https://www.amazon.co.jp/dp/B00G9IVVQ4/ref=pd_sbs_60_t_2/357-6200981-4178340?_encoding=UTF8&pd_rd_i=B00G9IVVQ4&pd_rd_r=580a0ca4-0a68-413e-80b4-f27ebaa38e53&pd_rd_w=BessW&pd_rd_wg=ZE67j&pf_rd_p=ca22fd73-0f1e-4b39-9917-c84a20b3f3a8&pf_rd_r=9K1ZY0J3DC9NMFXQVGXF&psc=1&refRID=9K1ZY0J3DC9NMFXQVGXF
nichocha33
I appreciate the input, I will wait for a set on jp seems like I feel more comfortable using it as I’ve never used rakuten. Thanks again
theamcguy
Fayetteville, NC
Anybody know the part number for the Stainless Steel Olfa blades for the SVR-2? TIA
BK13
PDX, OR
So with Frank's not selling KoKen any more, I've half-heartedly been looking for a couple of sets of the Surface Drive sockets (2310 set and 3310 set) and Tone's stubby silver impact sockets (I can't remember the part number) on Amazon.jp. Is there a secret to search terms? I really expected to be bombarded with results, but my responses seem pretty limited....
scubadoober
Amazon.jp will auto-correct your search term by adding spaces. There will be an option under the search bar that says something along the lines of search original or did you mean. It has something to do with the translate function on Amazon.jp.
E.T.
NV
And searching for the exact part number/ model number gives the best results.
RKA
PM me. I know I've got a set of surface drive's buried in the back of a drawer that I've never used. I just don't recall exactly which, but I can check tonight and get back to you.
I was able to find by searching the full part number (RS2310M/11 or RS3310M/12). But at the top of the results, it tells you it tried to translate your search results. Click "Undo" so it will search using the exact string you entered. That should turn up the sets. This may have been your issue...Amazon's smart search engine is unintentionally screwing up your search.
*edit* sorry, I was typing this while the other two responses came through. Anyway, that's your answer.
mr.lemons
UK
SVR-2 takes 9mm blades.
Olfa Stainless Snap-Off Blade 9mm (Pack of 10) = AB10S
Olfa Stainless Snap-Off Blade 9mm (Pack of 50) = AB50S
Link to the different blades here (UK website). The black 25% sharper blades look interesting.
https://www.olfatools.co.uk/products/2-Snap_off_Blades
Please confirm before buying, I have not purchased extra blades yet so this is just what I gather from looking at the website assuming that the SVR-2 takes any 9mm blades.
jimmyin3D
southbay, CA
Yeah searching on amazonJP can be tricky, they use a lot of romaji (English words written from Japanese, surface drive= sa-feisusokettore-rusetto)
Here’s the 3/8 shallow:
https://www.amazon.co.jp/dp/B004IKTV5I/
1/2 shallow:
https://www.amazon.co.jp/dp/B004IKTWCU/
Look up the Koken catalogue on their main website it helps knowing which sets you want.
RKA
Anyone have any feedback on the vessel 1/2” impact driver? It looks to be around $5X shipped from the US Amazon site. I didn’t find much when searching this thread, which was a bit surprising. Alternatively, a Koken AG112H, however than would ship from Japan, so I’m looking at around $125 shipped, which isn’t too appealing for a once in a blue moon tool.
Dave455
Sussex, England
I have the Vessel 1/2” impact driver. Mine is quite old, but I don’t think the design has changed much. It’s an o.k. tool, and has survived repeated use on brake discs over the years, but it’s nothing special.
The Koken Attack Driver is in a different league, probably the best impact driver on the market. I bought one despite owning the Vessel. If I didn’t own either, I’d go for the Koken.
Although you might think that you won’t use one of these much, you tend to find uses once you have one. If you have a stuck screw to remove, these tools put everything in your favour. The hammer blow ensures the driver doesn’t slip out, the shock alone seems to help loosen things, and the sharp twist usually does it’s job. Great on glued or bonded screws too.
Bear in mind that the Koken set you have chosen includes a fair selection of impact bits, which add to the price.
FSUwelder1212
FYI Frank does still sell Koken. He just isn’t dealing with Koken USA anymore. I emailed him a week or 2 ago asking for clarification because I’m looking for some koken items I can’t find on Amazon.JP
M6erfan
'Merica!
I don't own the Vessels but they've been making those Impact drivers for a long time and have a good reputation.
I do own the Koken AG112H set and use it often, I like that it comes with an assortment of bits but I did add some long 8mm impact bits. It is a beast for stubborn fastener removal. For me the Koken AG112H was money very well spent.
If it's going to be a 'once in a blue moon tool' for you why not pick up any one of the $35 domestic jobbers that are available?
M6erfan
'Merica!
Is that right? So he can still get the full Ko-ken catalog? That would be great!
mr.lemons
UK
One week at work and I'm sold on the bit magnets. They don't get in the way if you keep them up on the hex part of bits next to the chuck and they provide a good bit more magnetism on the tip.
Surprisingly they got a bit of attention at work. A few guys came over to ask about them and want to get some for themselves.
I see Makita sell one similar as well as some of the Chinese websites.
RKA
Thanks Dave, FSU and M6! I reached out to Frank to see what he could do. He has the other variation with 4 bits but I definitely want the set with the torx bits included.
Getting an inexpensive Taiwan set...yes, that would be the smart thing to do. I was wishfully thinking someone would give good feedback on the Vessel and that difference was not justifiable. Were it not for Dave's comment, I would have settled for the Vessel and left it at that. But having an obsession with good tools sometimes pushes me in the wrong direction.
1foxracing
Tuscarawas Co, Ohio
