6, 8, 12 Point?
Teken
The Bad Lands
How many of you have 8 point socket / wrenches? I don't know how many times I needed a 8 point just for that odd angle or that last nth degree of access, and that 8 point would have saved my bacon.
Why do you guys feel the lowely 8 point has not been as popular as the 12 point standard? :headscrat
I am looking in my tool box's right now and am hard pressed to count more than 24 sockets / wrenches that are indeed 8 point. All the rest are standard 6 / 12 point . . .
Your thoughts . . .
cruiser808
Hawaii
Hi Teken - while I can't really speak to the popularity of 8-points, I can tell you I use an 8-point socket to open the plug to lube my FJ40 birfield joints.
pedro1990
well, im gonna go out on a limb and say very few things use square head fasteners these days (if any?). the mechanics set i bought has sockets 1/4 thru 1/2 and i say i have never used most of them. Unless you work on antique machines/tools frequently, you may only run into a handful square nuts in your life. most of the time i just use a open end wrench if i run into such fasteners. i would only buy them again if i had every other socket type already.
Scout Driver
South Dakota
We use 6 points a vast majority of the time due to the fact we are working on older projects that tend to be seized from rust or the fact that they haven't been apart in their existance (sometimes 50+ years). 8 point sockets are handy for anything with a square-drive plug, such as a tractor rearend housing.
On a separate note to cruiser808.....you have an FJ40....:bowdown::bowdown::bowdown:....wow!:drool:
Scott
willf650
I use 8 points on a fairly regular basis but I'm not an auto mechanic. I work on HVAC equipment and the majority of set screws that hold large fan hubs on the shaft are square head. Aside from this one instance I doubt I would ever really need one.
06wt
chicago 434 UNION CARPENTER
i know 8 point as double square, cuz i have yet to come across 8 point hardware. but its nice to have a set its not used often but they are handy if u turn alot of plugs
Brad54
Your thoughts . . .
I don't mean to sound snotty, but your post makes it sound like you think 8 and 12-point sockets are interchangeable. Especially when you talk about the odd angle or the last nth degree of access.
8-point sockets can only be used on 4-point, square fasteners.
-Brad
cruiser808
Hawaii
Scott
Well said Scout, and thank you. :beer:
T
Teken
The Bad Lands
-Brad
Nope valid Q . . . I did not write it out as clear as I was thinking about it. I believe what I was trying to say is if there was a tool that was in between such as a 10 point wrench / socket which I know they make but are not as standard in the regular name brands.
With a 12 point it will grab a square, but it will be at the corners. Would a 10 point not be better in this case with more area on the flat surfaces?
cruiser808
Hawaii
:headscrat
Don't mind me, I'm just old school, but is there such a thing as a 10-point socket? :headscrat
sk farmer
nd
i doubt it but one never knows. i have an s-o penta socket. the only app. i know of is on water valves and or gas valves in municipalities or industry. i know i sure don't have any were i live.
sk farmer
nd
Okay Teken, thanks. I'm convinced. What is it used for?
if memory serves me right it is an obscure automotive application wich means in a few years it will be on all kinds of stuf and you will have to buy a whole assortment of tools. :spit:
Brad54
Um... still not getting what you're trying to say.
The points of the socket must be a multiple of the points of the fastener.
Most bolt heads are 6-point. Hence, a 6-point socket is always my first choice because it gives the full surface engagement you're talking about. A 12-point socket (or box wrench) grabs the corners of a 6-point, and gives the multiple "angles of attack" you're talking about... "wrench won't fit on it at THIS angle, but move it a little, and now it does."
There are special aftermarket engine fasteners that use 12-point, but other than those and a few special fasteners as others have mentioned, it's pretty much 6-point bolts.
A 10-point wrench or socket won't fit a 6-point bolt. It'd have to be a 5- or 10-point bolt. You can't use a 6-point socket on a square pipe plug or antique square nut. Same principle as using a 10-point socket on a 6-point bolt.
-Brad
bgott
Houston, TX.
If you look at an eight point socket, the points are pretty sharp. If I run into a rounded off hex I'll get the smaller closest sized eight point socket and beat it down onto the fastener. The eight pointer will usually grab on and get it out. At least, it'll get the fastener out if there was any way of getting it out.
MattT
You can also use 8 points to fit taps in them and reach into difficult places that a tap handle won't.
Tap sockets, with o ring retainers, are much better for taps that 8 point sockets.
I don't use 8 points all that often but when I do use them on pipe plugs and lag screws they sure do speed up the job.
