Gimmicks...
HotWire
Montana
I’m curious as to what tools you thought were gimmicks until you actually tried them.
Mine would be the popular new Oscillating Tools. I thought they were a joke; now I’m grateful to have one.
aka Larry
Eastern, NC
All I know is they (Oscillating Tools) are not created equal. I bought a $20 Worx model on Ebay and the oscillation was not limited to just the business end of the tool. I could hold it for about 30 seconds at a time before my hand said stop.
619DioFan
San Diego , Ca.
Two that I have that come to mind are A) HF flex head ratchet that has a second flex joint in the middle of the handle. bought on a whim , has come in handy many times.
B) HF extra long needle nose vise grip style pliers ( they are around 15'' long ). have also come in on many occasions.
engineer2
Chicago burbs
One of those telescoping sticks with a magnet and a light. Menards sometimes gives you one for your birthday. Pretty handy when you drop a 10 mm socket into the depths of a modern engine bay.
Telescoping 24-36" level. Bought it on a whim and it's very handy for headers, pre-hung door heads, and situations where you are between two objects..
mobiledynamics
Gotham City
oscillating tools are not new. indispensabile per your pic alludes. both during construction if not post construction in finished stuff
theoldwizard1
SE MI
Funny thing is, oscillating tools are almost an exact of an orthopedic "bone saw", just a lot larger ! Those have been around for a long, long time (air powered and water cooled).
CR888
Ratcheting adjustable crescent style wrench. I have 2 made by caralous (Taiwan). Not as good as say a bahco or Irega but they work and do ratchet. It was handy removing an outdoor water tap the other day.
consti2tion
East Texas
My oscillating tool has been invaluable, especially when I put the floors in my house, great for trimming up door stops and door trim. Just a fantastic tool that was money well spent, I just need to invest in a cordless one now.
M_George
Eastern Pa.
BFBOB
I inherited one of these from my father in law. I had no idea what it was. I have the craftsman version so I googled the part number. Its a lawn mower blade removal tool. I tried it out on my push mower and it actually was pretty handy. Beats standing on block of wood holding the blade.
https://image.sportsmansguide.com/adimgs/l/1/178075_ts.jpg
WHAAAATTT? I've never yet had a blade that didn't fall off of its own weight (after removing the nut)
joe_padavano
Northern VA
MoonRise
For those questioning/wondering what the item is/does, it holds the blade in place while you remove the blade bolt.
Not a blade/gear puller, just a 'bracket' to keep the blade from spinning as you remove/install the blade bolt.
Still up to you to remove the rusted in place blade. :lol:
About $10 or so, well worth it. IMNSHO :thumbup:
And yes, it is WAY better than trying to jam a block of wood against the blade, hold that block in place, and then unbolt the blade bolt with your fourth hand. And then put the block on the 'other' side of the blade as you reinstall the blade bolt.
A 'good' OMT is also quite handy. It certainly makes certain tasks doable or more easily doable, compared to other possible methods and/or tools.
:beer:
mobiledynamics
Gotham City
As much as cordless has replaced many of my BIG cordered (super hawg, reciprocating (even my Hilti reciprocating), I have yet come across a oscillating that will replace the Fein. Luckily, the fein comes with a decent 15+ft cord on from the get go.
Bacon!
?? A mower blade holder would just slow me down. I use a ramp shaped piece of pressure treated wood that does not need held down. It's maybe 10" long and 3.5" wide on one end and tapers to almost nothing on the other end. Granted my mower deck has straight side areas on it, I could see the wood block being ineffective with deck sides that only have curved areas.
Miss the Pontiacs
Saskatchewan Canada
The thread is about gimmicks, whether someone feels they are useful or not.
I wonder how many were sold?:headscrat
Den69rs96
Central MA
I thought the same thing. Then I used it. My mower has baffles all around for mulching so it makes wedging anything more difficult. Its much faster using this tool and when its time to reinstall the blade, its already in position because it doesn't need to be removed.
Spacey_G
Step drills and speed squares are gimmicks? Maybe they started out that way but proved their worth for so long that they're not consider gimmicks anymore?
kelpaso1
MEMBER EMERITUS
New Brunswick
:beer:
An impact gun makes that "tool" useless and un-needed.
dacan23
RI
One of the most common used tools I have, I also have the ones which I think are intended to grip hoses.
dacan23
RI
I use an old oven mitt to grab the blade to remove the bolt, I felt like a genius when I first did it.
ItsNemo
Canada
:beer:
Impact wrench my dear friend...hold blade steady with a gloved hand, brt brt and off.
Gimmick tool....Lisle Exhaust Hanger Pliers. I will never do another exhaust without them.
crasher98
NW LA
A blower like this came with the very first cordless tool set I bought:
View media item 100282
At first I thought it was useless filler, like the 275 hex keys that come in 300-piece tool sets, but I was wrong: years later I still use it all the time. Very handy if you don't have access to compressed air!
sparky 1971
Central Iowa
Jawhorse - One of the best tools invented in the last 20 years.
:beer:
I have two. I bought one for work that I leave on jobsites. I used it at home often enough that I bought another to keep in the shop.
Of course, when I watched the 30 minute infomercial advertising the Jawhorse about 12 years ago, I thought "what a joke".
Miss the Pontiacs
Saskatchewan Canada
got one, tried it a few times it works. good if all you have is a manual ratchet or wrench.
That makes 2 for sure you and Den69rs96. If my FIL would have seen it he would have had one too.
I bought a set Of Greenlee Fibreglass pulling rods. My buddy liked to use a golf ball retrieving stick. Thought the rods were silly, until I fished a 2” conduit bend with the rods not having to untie the cable and and retie to a a fish tape. Also not having to fish the conduit to begin with.
He eventually went and bought a set. But it does take time for him to wrap his head around new innovations from the old school methods. Great guy just likes his routine. :beer:
soloz2
Western NY
Jawhorse (I have the Craftsman version) and Jawstand.
I seriously thought about getting one of those blade holders after the first time I pulled the blades off my lawn tractor after the dealer used an impact to install them. I quickly realized an impact wrench and a gloves hand was easier than busting out my breaker bar.
