pneumatic cutoff tool quality
littleboss
I don't get much life out of my pneumatic cutoff tools. I have had several Campbell Hausfeld and Tractor Supply units. I just bought a IR to see if it's any better. Basically after using them a few times they don't have any power. I always squirt some oil into them before using.
Do they wear out that quick because they run so fast? Or do I need to find some better brands?
Thanks
lis2323
Perhaps you are OVER oiling? Usually a drop a day is sufficient. Or insufficient air volume or pressure?
I have a bunch of CP’s IR’s and they are fine. My fave cutoff tool is my extended reach Aircat.
ZRX61
Solar Blight Valley, SoCal
I had a Matco die grinder that lasted me for years. When it finally **** the bed I bought a new Matco.. it lasted two weeks.
Years ago I bought some cheapo ($7.99) die grinders from Horrible Fright with the plan to just throw them in the trash when they STB... So far they're all still working just fine.
metaleltr
Western Ohio
Spray rake clean in the air inlet. Fire the tool up hustling enough to flush the **** out. Oil it with just a drop or two of good air tool oil. Make sure you air supply is clean and dry.
finn
The UP, God's country
Sounds like they are mucked up internally. Maybe try flushing them with PB Blaster, Kroil, or even WD 40, then using an air tool oil like Marvel.
I have some air tools that are thirty or more years old that still work fine, although obviously not in a commercial environment.
That extended Aircat rocs, though!
joshmodelskidoo
mid western michigan
Do you get water coming from the exhaust? My cheap hf still works fine, actually better than when it was new. I used to have to give it a spin to get it started. I ran a shot of carb cleaner through my air tools then oiled them up a few times but im sure there are way better options
gungatim
west mich
take it apart and see how it works. you'll see why it isn't working. either you are getting dirt in the air supply, scratching and pitting the cylinder/vanes, or over oiling which makes the veins stick and not fling out and seal. once you get one apart you'll see how amazingly simple they are, and the only way they make power is by the vanes...and yes, I've had some where the veins were defective from the get-go and never made much power (cheap craftsman one).
bob15
Northeasten, CT
Sounds like they are mucked up internally. Maybe try flushing them with PB Blaster, Kroil, or even WD 40, then using an air tool oil like Marvel.!
To add to this, it is Marvel Air Tool Oil, not MMO:
joe_padavano
Northern VA
^^^THIS. I've had this problem on several air tools. Disassembly and cleaning made all the difference. Of course, once I have it disassembled, I typically put in new vanes. I've resurrected an air nibbler and a Hutchins 800 orbital air board this way.
B_Bimmer
Eastern Iowa
Clean, dry air is critical for performance and longevity in an air tool. That said they are tough and it's amazing the abuse they will take.
driz
Northern NY
Many times just teardown and reassembly magically does the trick. Why , who knows. I’ve got HF and IR and had more headaches with the HR . One of my HF dates 1990 wimpy but works.
fsae0607
San Fernando Valley, CA
Right? I have 90's era HF air tools and they won't die! Of course, I oil them whenever I use them.
joe_padavano
Northern VA
I've noticed that too. I suspect that it's just that the vanes get stuck in the rotor and teardown loosens them up. As I said, once I have it that far apart, I just stick in new vanes anyway.
L
littleboss
I will take it apart, it will only cost me my time.
finn
If you do remove the silencer, wear good, high quality hearing protection.
Hearing aids cost around $5k.
I wouldn’t recommend removing the silencer....it’s not a smart move.
driz
Northern NY
Let’s be really honest here, there’s no such thing as a quiet air tool. I put on something every time I pick one up . Same goes for battery drill drivers.
danielbuck
I don't know, the aircat die grinders are pretty damn quiet.
