Finally getting tired of working in the cold and need a real heater. Wanted to go the radiant tube heater route but cant afford it. Started looking at the hanging furnace route.my pole building is 30x40x10. Wrapped with tyvek and R25 throughout .no concrete insulation other then vapor barrier
Obviously alot of factors, but do they run alot to hold temp?
How efficient are these style if i leave it at 45* or whatever a thermostat goes down to. I will need to set a separate lp tank, will 250gal be big enough to make it thru an iowa winter.
How noisy are they? We do have get togethers often out there.
Approximately What size btu would i need.
Thanks
Sent from my SM-G930R4 using Tapatalk
Thanks
