Testing electric motors
jabberwoki
puyallup wa usa
So I chatted with a sparky about testing motors both single and 3 phase.
He said to put one ohms tester lead on each power leg and the other on another power leg and you should get a reading.
Then do the same thing but do a power leg to ground and you should not get a reading.
What say ye ?
r_olson_06
SD
This will check to see that there is no broken windings with the phase to phase measurements. The measurements on the 3 phase motors should be within 10%. Single phase is different.
There should be infinite resistance between any phase and ground. This is not a perfect test as it may not pick up a pin hole in the insulation. A megger would be better.
Cuba_pete
WA State
A megger is a resistance tester that generates higher voltages to help find insulation breakdown, in this case, for a motor.
Basically...
It’s not a typical tool in most shops, but some older elmers might have one.
J
jabberwoki
puyallup wa usa
Welcome Noob.
Thanks for the info, I do have a guy in Centralia to go too I was just wondering how good the above testing method was.
So I`ll plan on going to see the Captain in Centralia.
MattT
"Old elmers" might be the only ones still using the hand crank meggers. Most of us went to the digital versions decades ago and still use them for the problems you can't find with a good DMM.
fitter30
Peace Valley,mo
I still carry both a hand crank megger and meter for three reasons. Cold weather meter display goes away, battery dies and to double check a reading. Only use it couple times a year.
walta
Dutzow Missouri
I agree any motor that fails one of the 2 simple tests is not going to work.
The test will weed out some dead motors but is far from perfect as many bad motors will pass the test.
Walta
MattT
Bad 3 phase motors that pass DMM + Megger + spin it by hand are extremely rare. That and a visual/smell check for overheating.
The caps, and possibly a centrifugal switch, do complicate things with single phase somewhat, but those problems are usually fixable.
MattT
So again will that mega I posted do the job for me?
It'll megger a motor, if it still works. What exactly is this "job" you're trying to do? If it's just testing something you've drug home from CL a quick check with a DMM then hooking it and seeing what happens is a valid test. If it blows the main breaker to your house you've got a ground fault:lol_hitti
J
jabberwoki
puyallup wa usa
Well I`m, testing the 3 motors that came with the lathe and the motor that came with the big shear.
I don`t want to ****** anything up any more than it might be so I`m going 1 step at a time.
