Most comfortable work boots?
RustyJunk
Pasco Fl.
What's the model number of the Belleville boots? The page you linked to has several different pairs of boots.
I have the Belleville 390 Des without the steel toe, I also use the Wellco T160's, they are almost the same as the 390's. Get 1/2 size larger so you can add thicker insoles if needed.
Hammer1963
Kentucky
I wear both Redback and US made Carhartt 6 inch boots lace up boots, but the key for me is the insole that I use. Pinnacle Powerstep. I suffered from the same and these changed my life. The relief was amazing
phred
NC
Used to wear Rossi slip one but the quality has gone down. Just bought a pair of Wolverine romeos. Comfortable and quick breakin. Waterproof too
ScooterFL
Key Largo, FL
Switched to the Australian Redback slip on's a few years ago, our Matco guy carries them on the truck. Used to go through a pair every year when I wore Diehards but these have lasted me 3+ years and are the most comfortable boots I have ever worn at work in 30 years.
jhonesmith
glassgow
Well I loved to wear shoes and most likely I love shoes soo much. I go for each week to get them clean. I want to get rid out of all the dust from my shoes. But when we go for a shoe we most likely desire to get most comfortable cowboy boots.
Well I have these and these are awesome for jungle wear and to dress like old generation.
Rinspeed
NY
Thanks everybody. I appreciate all the suggestions and have looked at what is available in this part of the world. I found a military place that sells combat boots with a safety toe, they "claim" to be for people who stand and are on their feet all day so will have a look into those.
Take a look at the Danner RAT boots, a little pricey but they last a damn long time. You also need the proper insoles for your feet. I switched to Power Step Pro insoles several months ago and my feet feel much better.
Hephaestus29
Indianapolis
Redwing ***** in my opinion. Our
workplace gives us vouchers for 200.00
worth of shoes/boots every 1.5 years there.
Only thing I found comfortable at Redwing
was their black flat bottom shoe.
I’ve had a pair of Danner boots for about
6 years now that I still wear but are for
the most part worn out, but some of the
most comfortable boots I’ve had.
Dave455
Sussex, England
If you’re on your feet all day, on concrete, then it’s fairly natural that your feet are going to hurt, though the swelling sounds nasty. If you look at places like machine shops, they often have rubber mats where people stand for this reason.
The only style of boot I’ve found that eases things are the type with the ‘airwear’ style squishy sole. Dr. Martens were the original’s, but they’re produced overseas now and quality isn’t what it was. I wear ‘Solovair’ which are made by the same factory that used to produce Dr. Martens. They offer a huge range of styles, including safety boots with steel toe caps, shown below.
I found when I was younger, that if I wore lace up boots every day I started to get some ankle pain. Apparently this is common, and is caused by your ankle getting weaker. I wear shoes or Chelsea boots predominantly now, and have had zero issues since.
jonesg
northern Maine/
the guys I know in construction say to avoid steel toe boots, they will cut your toes off.
Better to have your toes flattened than removed.
Cheepbeer
NW Ohio
I've worn steel toes most of my life. Worked construction, too. I've seen quite a few injuries from not having them, but never seen one from wearing steel toes.
I went to horseshoeing school back in the 80's. That was their theory. Two of us with steel toes got stepped on, no problem. Two without went to the hospital.
bigdave_185
Utah
I have been in construction for 26 years. I have tried many kinds of boots from Wolverine Durashocks to Justin to Red Wing. After discovering Thorogood wedge soles, I will never buy a different brand. or style. They make a steel toe version, but I have not and will not try them.
Exact same boat, Iv welded, ran a cabinet shop, framed residential, ran heavy equipment, iv worked in the office and these have been my favorite boot. Do watch out for hand made irregularities. I have opened a box where one boot was labeled wrong size. But I keep a working pair, a nice break on pair and happy with they
pennsylvaniaboy
I feel like this is more myth and legend than fact.....But I do find comp toe to be a more anatomical fit.
redragoon
Greenville SC
My most comfortable boot is an older steel toed Georgia Boot. My company switched to Red Wing, so I haven't been able to get more.
My most comfortable work shoe is a Skechers Steel Toe with a rubber slip resistant sole.
My first job out of college was at a R/D engine testing facility. There was a 70yr old man who worked there every day, mostly on his feet, wearing the same safety shoes every day. I figured if they worked for him, I should try them. I think I've bought 6 pairs over the years. They quit making the original steel toe version, but they are the same design otherwise.
https://www.skechers.com/men/shoes/work-soft-stride---galley/76759.html
Skin
Boston
It's been tested including on tv by myth busters. Safety toe will not turn into a guillotine and cut your toes off. The real downside is steel toe can get colder in the winter but some companies offer composite versions.
tarbellb
Oregon
Thorogood (USA) for traditional lace up
Redback (Australia) for slip on
Bought some USA made Danner a while back, compared them to my Thorogoods.
No contest, the Danners were inferior, more single stitched, thinner leather, cheaper insole, etc...
CentenIJ
Quality socks and proper sizing I would say are key when wearing work shoes all day.
I wear Red Wings Dynaforce and like them. They do take some breaking in but they fit nice afterwards. I pair them with Snap On socks and its a pretty comfortable combination.
One thing to mention is that red wing does have 5 different width sizes which might contribute to fitting issues if you don’t have the right one. I wear a EE wide and I wouldn’t say my feet are huge.
autobon7
Been wearing Keens for several years and they are not bad. Always on the lookout for something better but the Redbacks look like they would be hot on the feet (in a bad stinky way). Whats you experience with this?
tarbellb
Oregon
Ive got Radbacks, real comfy and not any hotter then 6" moc toes. Maybe even more breathable due to the mesh on the sides.
My Keen boots sole fell off after 5 days... they are not what they used to be.
jhonesmith
glassgow
Hi here the most comfortable boots for cowboy, You can use these boots for horse riding. These are the best cow boy and comfortable shoes.
If you are a good horse rider you must have these. If you want to work in your office all the time then these are the best shoes ever we had. Or if you want to go out for a party in night. These shoes are best for a party wear.
67CarGuy
Outside Boston, MA
Well thanks to you lot, I just dropped over $1k on multiple pairs of Thorogoods, Keens, etc. in the hopes of finding a pair that'll fit well, be comfortable, and keep my feet safe. Thank goodness for free shipping and free returns! Fingers crossed at least one pair works out...
Legion Prime
Leelenau County MI
Snap On socks..... bahahaaha can you warranty them?
I agree good socks are a huge help, I really like
Darn Tough- USA made w/ wool blends and lifetime warranty (Ive used it, easy)
https://darntough.com/collections/m...-merino-wool-steely-boot-midweight-work-socks
I've found Darn Tough to be a little tight across my instep. I have high arches so maybe it's just me but Smartwool are my go to. Point 6 IIRC are from the people that started Smartwool, sold it then got bored and decided to do it all over again but I don't find them as stretchy as Smartwool. Regardless, once I got used to wearing wool socks I loath days when I grab a pair of cotton socks from the drawer.
autobon7
What was the difference when switching to wool? Just wanting to hear your experience before buying some.
bigdave_185
Utah
Exact same way here, I wear the Fits brand a lot.
Wool or mirror blends They are softer on your feet, I find my boots smell better longer, I also find my feet not so soaked after 15 hrs in boots
richfinn
Leeds, Yorkshire, England
I always go a size up for workboots, feet swell up when you work 12 hr shifts and more room for sockage in the British winters!!!
Under Armour are now my socks of choice as they last a very long time and cheap enough
tarbellb
Oregon
Wool socks- even 50%+
_ excellent thermal handling both hot and cold
_ better cooling = no stink and can wear multiple days before washing
_ also because the cool better they can be thicker and more comfortable
captain14
CarGuy67,
Let us know which boot(s) you are going to keep to wear. I’m looking for a good pair in my size (15 W)).
Legion Prime
Leelenau County MI
Sorry I didn't see this sooner. The biggest difference besides texture is that wool wicks moisture away from your foot whereas cotton just absorbs it like a sponge. The wool dries out a lot quicker and is antimicrobial so your feet don't get to smelling as bad at the end of the day. I keep looking at other brands of wool socks because the SW/DT/P6 cost per pair about what I'd pay for 12-16 pair of cotton socks but the other "wool" socks I keep on finding are only 30 or 40% wool if not less with the remainder normally being nylon or acrylic or something. I don't even bother with them. I started about 6 or 7 years ago just buying a pair of wool socks whenever I'd normally buy a pack of cotton socks (whenever I started getting a little low on socks). I bought fewer socks more often but within a couple years I had a majority of wool socks, was used to the different feel on my feet and absolutely despised wearing cotton socks for anything more than a couple hours. It does take a little getting used to but unless you're allergic to wool you will wonder why you didn't switch sooner. The ONLY redeeming feature cotton socks have is that they're cheap and maybe a little stretchier, that's it.
I'm not familiar with that brand, I'll have to buy a pair and check them out. Thanks!
