Looks great on the bench! I just picked up a 614 1/2 a couple weeks ago and you had me curious, went back to look but mine doesn’t have the same numbers on the dynamic... just repeats the 614 1/2. Guessing maybe from different eras? Mine does not have replaceable jaws, I know some models did... are yours replaceable?
Smitty: Yep, me too but there's 7-1/4" sticking out the back, no matter how conservatively you reckon on opening, surely it's 7-1/4".
It's definitely 7-1/4", maybe they changed slightly by era?Catalog page says 7in opening for a 614 1/2.
I bet you’re right on the number being possibly a series number.No, mine are cast in. I think you're right about the eras.
I found some other pictures and the 5" has "5-6", the 3-1/2 has "3-1/2-6" so I reckon it 's jaw width - "6 series vise". Just guessing......but seems plausible.
You'll like the 614-1/2, all Athol vises have a buttress thread and spring preload of the screw. They are - IMO - up there with Reed in quality.
Where can I locate some of these bolts. Thread is 1/4-20.
.thank you
Sent from my SM-G955U using Tapatalk
I heated the tang up and peened it onto the handle. I then sanded the end flat and cleaned it up on a wire wheel. I was pretty happy with how it turned out with minimum tooling.
Sent from my iPad using The Garage Journal mobile app
Thanks Ken. Somebody could get the tang hot enough with a Map gas torch so a forge isn’t necessary. I also put a well in the top of the ball to give the steel somewhere to go. I got the balls from Industrial Metal Supply. They have quite a few stores in my area.
I just dug out this old AM Co 44 vise. I think it was my grandfathers. Am I correct that it is an Athol Machine/Starrett. Any idea how old this would be? I am also curious about the swiveling jaw on the back, is it to be removed and replaced with other jaws? or just to swivel to hold an odd shape? It is the first vise I have seen with a "quick" opening feature, lift and pull it out.
A woodworker would use his good eye and a angle grinder
nice job smitty!
