Cruiser787904
- Joined
- Jul 24, 2016
- Messages
- 7
Hi Guys,
I just bought this heater for my shop and got it all hooked up as per their directions. I followed the start up procedure and when I have everything powered up, gas on, and I call for heat everything works as it should except it doesn't fire. This is what it does:
1) Call for heat and inducer motor starts and pulls a draft
2) Igniter starts to click and spark as it should
3) Audible gas valve click, and I can feel it actuate but no gas flows and burners obviously do not fire.
4) It repeats cycle 3 times before going into lock out and circuit board flashes 2 times
I am hoping someone might have a tip or trick to get this up and running although I think I have a bad gas valve. I did convert this unit to propane and set the pressure by bottoming out the pressure adjustment screw and then backing it out 1.5 turns per directions.
I just registered it for warranty, called for service which I got cut off and just created an account with Mr.Heater and logged a ticket. So I am waiting their reply and I am assuming I just have a bad gas valve since everything else checks out.
Any thoughts, tips, tricks? Has anyone else had a bad gas valve out of the box?
