Astro's new 936, the biggest baddest geared air saw on the block
Astro_Pneumatic_Tools
South El Monte
Video:
The average cost of a gear driven air saw is right about $300 across all the options out there.
  • Which we felt was too much
And the cutting capacity of these geared air saws are from 3-5mm
  • Which we felt was a big difference compared to a standard air buzz saw, but could be improved upon
And the gear transfer design many of these use are the exact same
  • Which we felt could also be improved upon
Lastly, most of these take air saw style specific blades
  • Which we felt was inconvenient, and for large tasks kinda **** if we're being honest
Astro's new 936 from our ONYX air tool line.
- A superior gear transfer design that's easily greasable
- 1/4" cutting capacity
- Around half the cost of other geared air saws
- Cuts through stuff like it's on a mission
SPECIFICATIONS:
Strokes per Minute: 7,000
Ave. Air Consumption: 4.0 CFM
Max. Rec. Air Pressure: 90 psi
Air Inlet: 1/4"
Net Weight: 3.0 lbs
Length: 12.2" (310mm)
Stroke Length: 10mm
Cutting Capacity: 1/4" (6.4mm)
Recommended Hose Size: 3/8"
Sound Pressure Level: 88 dB
Includes: 6"-14T, 3-5/8" - 32T, 3-5/8"-24T
ItsNemo
Canada
So this takes standard sawzall blades? or jigsaw blades?
How long does it actually take to cut 1/4" plate? IPM?
A
South El Monte
Metal cutting Sawzall blades (1/2" wide shank), 6" variety for best results.
No on else lists IPM of their saws so it wouldn't serve for much comparison. But it cuts through 1/4 a bit quicker than the comparables we have been able to test with on 5mm.
Mr_B
Reading
looks good and not too bulky .
Just sort of thing I looking for quick cuts in auto repair work .
I see it around 160bucks, looks a good value buy for time saving cutting tool solution.
Good job AP (thumbs up)
Has SMA tested and approved ? ...
A
South El Monte
Can this work on stainless exhaust and cats?
Blades are the issue with stainless. I would recommend the carbide metal cutting blades for Diablo.
Yup, material is down to the blade design
It's being field tested, but not at SMA as of yet. Not sure Eric does a lot of reciprocating cutting, although I would be happy to send one.
Mr_B
Reading
I reckon he might find good use for one ... never can have too many cutting tool options
I'll be getting one for cutting suspension bolts, exhausts/bolts and the likes, use sawzall and air hacksaw and this geared air saw seems likely useful and more compact than sawzall .
RKA
With the amount of rust I see on the SMA channel, it's hard to imagine that he wouldn't use it if it showed up in the mailbox. :) I love that it will use consumables I can easily pick up at the local box store!
Hakeem
Chicago
I was looking at getting one, mostly for cutting bolts and other components where a grinder won’t fit. This would be used in place of a corded sawzall.
@Mr_B , @Benito , and anyone else who has one - any updates on how it’s being treating you?
Beerhippie
Far NE Oregon
For exhaust and other tubing that will be welded, a clean, square cut is of first importance. A recip saw is less than ideal for this.
Unless, of course, you plan to use this "in the wild" after dark--and then 88dba is a little loud, and it's hard to run while hauling a compressor.
Mr_B
Reading
Good tool, it far nicer than the common design air saws .
Advantages are pretty compact size, punchy cutting power and fact it takes standard metal sawzall blades which means blade options/costs/availability are good .
It one of those tools I don't use daily but when you get a shity situation that tricky to cut this tool can be just the ticket and make what could be a ballache a 5 minute job with a grin on your face ....
Anyone with good air system doing mechanical repair or light fabrication work should own one of these as not that expensive for a good blade cutting tool of good thoughtful design .
Hakeem
Chicago
Yeah the ability to use a regular sawzall blade is what caught my attention. Using the thin blade to cut bolts seized up in bushings is what would really be nice. I do a lot of work on ford transits and they use these aluminum bushings on the control arms and getting them free is such a battle. Aluminum means oxy acetylene doesn’t work and the surrounding components get in the way of a grinder so it can be a nightmare. Looks like I’ll be adding one of these to the arsenal soon. Thanks for the feedback 😎
