BTL-A4
What do you all recommend for cleaning pitch and gunk off table saw blades? I cut mostly MDF, 2x4's from the big box stores, plywood and oak.
I have used oven cleaner. It is lye in a spray can .... to best of my knowledge.
Less efficient cutting leads to heat build up. Especially a problem in ripping hardwoods.Unless its affecting the cuts you make why bother?
Ammonia in a bucket. Only need enough to cover the blades. I use a plastic scrub brush after soaking a few minutes.
Cut the bottom portion off a 5 gallon bucket leave the bucket bottom about 3/4 inch deep and that is all you need for a pan to soak the blades in. I have used Oven cleaner and others like simple green but save the oven cleaner for the really nasty blades.
This is absolutely brilliant! How come simple things like this always elude me? I always used an old cookie baking sheet, which never really worked all that well, and never seems to be able to be completely flat.
The bottom portion of my next Homer bucket from Home Depot will now become my saw blade pitch remover holder!
Excellent!
Jim
If you like that, just use the 5 gal bucket lid (HD sells them separately). They have a 5/8” lip on the top side. No cutting involved.
Kerosene and oil, 50-50. After you're done with the blades, use it to soak all of your cast iron machine tables, and leave it on over the weekend. Some will soak into the table to help prevent rusting, and just wipe off the excess.
Isn't that going to leave residue on the tables? Maybe the kerosene will thin the oil down quite a bit.
I love a lot of these answers and will give some a try! I have soaked blades by laying them in tinfoil and rolling up the sides. Still need to be careful not to tear the sides but there's always more tinfoil..What do you all recommend for cleaning pitch and gunk off table saw blades? I cut mostly MDF, 2x4's from the big box stores, plywood and oak.
