Hopefully there's a plumber on here who can give me some sound advice. I'm wanting to relocate our washer/dryer, which is currently sitting in a half bathroom on the main level. This is the bathroom that our children would primarily use; however, the master bathroom is the only full bathroom on the main level. With that said, I would like to convert the half bath by the kids' room to a full bath, but I'll need to relocate the washer/dryer downstairs in the basement.
The area I have selected is chosen due to access to the main drain pipe, the breaker box, and hot/cold water supply lines. It's all right there plus there is a random room that isn't used for anything other than holding stuff that could be moved or thrown away.
The only real concern I have is making sure is that the drain for the washer is designed/installed correctly. I was thinking that I could just put a wye or a sanitary tee (not sure which one I should choose) into the main line and run it over to where the washer will be. It would probably be ~8 feet away. I've read a little bit about vent lines and wasn't sure if this was required and how I would even go about doing something like that. So hoping the garage journal experts can help me. Hopefully the pictures explain the situation thoroughly.
Thanks in advanced!
Explaination on pictures:
I have given you a paintbrush blueprint overview of what my third garage looks like. This is a garage that exits out of the back of my house and holds my garden tractor, and other things like that. In red I have the main line shown.
I think the other two pictures are pretty well explained with captions. If not I'll be happy to answer questions.
Thanks in advanced!
