Hello forum,
I am in the process of installing a 100A subpanel to my 200A main panel. Here is my plan followed by my questions:
- The subpanel is to serve the following purposes: 20A breaker for grizzly table saw. 50A breaker for quincy 5HP compressor. 20A breaker for master blaster air dryer. 20A breaker for washer/dryer in laundry room. 20A breaker for garage doors and lights and some outlets. 20A breaker for bendpak HD-9 lift.
- The run from main panel to the subpanel will be 90% in unfinished basement ceiling. Rest in finished garage.
- The total distance is less than 50 feet.
- Speaking with the inspector of my town, there are no special requirements. They follow NEC 2017. Whatever the book says is what is needed.
Questions:
- I would like to use copper wire because I dont want to deal with AL. With that in mind, what type of wire/size do you recommend?
- What size of PVC conduit is needed? Yes I know I can bore holes in joists and run SER. But i want to have a clean/professional (and safe) installation.
- I have plans to build a detached garage later this year. The detached garage will have 2 lifts, another compressor. It will be used mainly for car stuff whereas this current attached garage as a workshop/woodworking. Common sense might say dont do the subpanel now, do it to the detached garage and move all your stuff there but I simply cannot have woodwork and expensive sports cars under the same roof. While some of the things in the current attached garage can move to the new garage (master blaster for one), some needs to stay (compressor, table saw, etc). So the question then is could I then run another 100A subpanel from this subpanel to the new garage OR do I need to run it from main panel?
This plan calls for 2 compressors in my house. There is good reason for this which is my sprinkler lines and their drain locations to blow out the water during winterizing being in the basement of the house. And the distance from where the detached garage will be to the sprinkler lines is in excess of 100ft making it very difficult to have only 1 compressor. Point being, I need 2 compressors. One in workshop/house/current garage and another in the detached garage, thus having 2x50A breakers in the system (one in each subpanel).
Your help is appreciated.
Questions:
