ClappedOutBport
- Joined
- Mar 30, 2016
- Messages
- 998
Today was a very productive day for me. I started on a bandsaw mini-pallet, replaced a molded in bearing and modified a mill vise for safer float-drilling.
It was more than a few days ago, but after getting my 1964 Willys Traveller with the stock 230 OHC Tornado started for the first time since bringing it home, I took her around the block for the first time:
Playing Tetris .... need a bigger one.
I made a new cross slide dial and assembly for my Atlas/Craftsman 12" lathe. Everything except for the lead screw and handle are new.
And after:
I designed the new cross slide to include thrust bearings at both ends, the dial reads on the diameter instead of the radius, and I have the ability to zero the dial out. Now I need to not screw up stamping the numbers on it.
Expert level Tetris.
Trying to get the 18.5 foot 1959 Ranchero squeezed into an already full garage. I think this means maximum density for all 2 wheeled vehicles as well as 2 Vespas in the back to the Ranchero in the garage. Gotta do another round tomorrow and see if it is even gonna work at all.
As it stands right now, I've got 10 bikes and 3 cars in a "2 car tandem". I think I can squeeze the Ranchero in for longer term storage, but it will come down to inches.
I love mine, but I've literally replaced everything in the engine bay except for the bottom end. There's a lot of stuff that can/will break on top of the engine that won't stop it from running but will cause a loss of performance. When enough of those things going wrong and it's finally noticeable it can be very frustrating as there's no simple fix other than replacing/rehabbing pretty much everything. They were never drag racers (I don't think even a stock GTS is capable of a sub 6 second quarter) but when running right they have loads of torque at any RPM and are geared for a top speed that will definitely put you in jail.
so I enlisted the help of some bubbly, and the kids.
How big is yours?
Did some sweeping and cleaned a new pistol.
Hey Passn', do you have any non -Motorcraft coils on that? Ford Tech Makoloco did a video with misfires/ shift probs... It's on YouTube.
Non-Motorcraft coils on right side causing interference with trans. wiring harness near by.
Just a thought. Good luck!
John
