After looking at plenty of pre-made "temporary" carport kits, I'm leaning to just going about it myself. It'll be more expensive, but I feel it'll be sturdier and allow me to get my exact dimensions i need/want to utilize. Instead of the typical 10' by 20' I can do 11'-10" by 21' which perfectly fits the side of my house.
So I went to home depot to brain storm, and came across the schedule 40 galvanized iron pipes. Seems like a good fit because they thread together, i can get all the fittings I'll need to make it work, and it's readily available. My only concern is, is that material okay for such a structure? I'll only have a tarp over it, and with a roof pitch of 45 degrees nothing should sit on top. I'm also in Arizona so i don't have to worry about snow potentially sitting on top nor do i have to worry about tornado's/hurricanes.
I was thinking of using 1" pipe, again it seems sturdy enough, and anything bigger i feel will be overkill. I was thinking maybe to use 1-1/4" for the legs, then reduce down to 1" for the upper structure. But even then I'm not sure how much of a difference there would be.
So what are your thoughts? Bad idea? I've asked around on some subreddits and some people suggested structural metal tubing. Which sure I'd be down for but i don't know how to weld, the material seems to be substantially more expensive, and i'd have to custom make all fittings for any sort of angles etc. I also liked the threads because it allows me to take it apart and bring it with me when/if i move. In my head i'm thinking "they sell those $200 kits with super thin aluminum tubing, why wouldn't a thicker walled tubing work?". But then again i don't know everything. Maybe there are some plumbers on here that will tell me how bad of an idea this is.
