I use my Festool TS 55 track saw just about every day. It came with a general purpose 48-tooth blade that makes fantastically clean cuts and lasts a reasonable amount of...
Ryan & EZ, which tool would you recommend someone trying to see if the Festool system is a good fit?
General wood-working projects, nothing too fancy.
Appreciate your feedback!
I'll send you a PM in a sec (don't want to litter Ryan's blade thread).
For me it all started with the Domino as it is tool unique to Festool until the patents expire.
It's been a while since I looked into it, but isn't that just a biscuit joiner?
I'd be really careful. You can get locked into their ecosystem very quickly and, in my opinion, the only reasonable reason to do that is if you are VERY concerned about dust collection.
That said, if you are... I'd get a midi dust collector, a ts 55 track saw, a track or two, and one of these: https://tsoproducts.com/tso-products-guide-rail-squares/
I have quite a few Festools. The Domino is definitely the most unique. It will change the way you build things.
One of the most surprising Festool though are their random orbit sanders mated to the vacuum dust extractor. It is really amazing how little dust gets loose into the air with this setup.
Ryan,
Looks very nice. A couple of q's:
It looks like you went for 2 layers of plywood for the desktop. What did you use for glue between the layers? Did you scuff sand?
Are the drawer fronts prefinished?
Did you edgeband them?
